9004 to 9007 wiring???
Old Apr 4, 2005 | 08:28 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
I am making a harness to convert from 9004 to 9007. I need to know what the wires are on the connector. If you are looking at the socket end (not the bulb end) of the connector, with the flat part facing towards you, what are the wires from left to right?
Old Apr 4, 2005 | 10:27 PM
maximazation's Avatar
http://forums.maxima.org/showthread.php?t=312531
that might help you, check out the pics.
Old Apr 5, 2005 | 09:26 AM
Dan's Avatar
Dan
I've already read through that whole thread. I just needed to double check the wiring because the pics are not 100% clear.
Old Apr 5, 2005 | 12:46 PM
Loe max's Avatar
Here is an easy test if you had trouble understanding it from the picture. Cut one of the left or right wires, turn on your headlight on lowbeam. If the headlight is on, then you just snipped the highbeam wire. If the headlight is off, you just snipped the lowbeam wire. Label which wire is LB or HB. Patch the wires that needs to be patched for the conversion to be complete.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
