eliminate speed gov. no CEL
Old Apr 5, 2005 | 07:13 PM
larryseibel's Avatar
i clipped the pink wire on the pcm and took it to a CLOSED COURSE and check out to see if it eliminated my top speed governor and it did. however i dint get a check engine light! i dont know if it has to do w/ the fact that my car is a 5spd but i dont need a toggle switch or nothing! did we know this already? shoulda done this mod 2yrs ago...i hate my own lazyness!
Old Apr 5, 2005 | 10:11 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
I thought GLE's didn't have govornors.
Old Apr 5, 2005 | 10:26 PM
MaDMvD's Avatar
HAHAHAHAHA I don't have a governor on my...CAHLEEFOHNYA spec...GET IT?? GET IT!!?!?!?! HAHAHAHAHHAHAHAHA I'm such a riot!!
Old Apr 6, 2005 | 02:00 AM
Supermax95's Avatar
gles didnt come with governers, or in 5 speed. is this a different max than the one in your profile? Or were you just embarrassed to have a GXE...=P
Old Apr 6, 2005 | 05:04 AM
mzmtg's Avatar
Minister of Silly Walks
The CEL doesnt come on right away. It takes a while.
Old Apr 6, 2005 | 06:24 AM
Killer99max's Avatar
Custom Molding King!
Yes dont worry, it will happen soon enough.
Old Apr 6, 2005 | 06:46 AM
when i bought the maxima there werent any emblems on it plus it came w/ pwr windows, mirrors, aluminum 15inch wheels, factory pwr sunroof and a spoiler so i assumed it was a gxe. that was before i knew that they didnt come in a stick but no matter what kind of maxima you own its a never an embarrassment if its nice. theres alot of gle on the org that will put your car to shame on the track and in the showroom. :
Old Apr 6, 2005 | 09:02 AM
Dan's Avatar
Dan
power windows, mirrors were standard. You'll know if its a GLE if its got auto climate control, black gauges, wood trim, etc. A 5 speed and black gauges is a sure GXE indication unless you've done swaps.
Old Apr 6, 2005 | 09:40 AM
MaximaSE96's Avatar
Maxima Owner
SE 4L....and ya ur CEL light will come on in approx.....5...4...3...2...1...0
Old Apr 6, 2005 | 03:16 PM
Supermax95's Avatar
Yes there are, and thats besides the point. I was just asking a question and joking around, no need to get butthurt about it.
Old Apr 7, 2005 | 07:42 AM
good call...damyou
Old Apr 7, 2005 | 07:50 AM
shmad's Avatar
so ur CEL did come on?
Old Apr 7, 2005 | 08:21 AM
G4nismo's Avatar
don't really care cause its not like u drive over 115 every time
Old Apr 7, 2005 | 01:46 PM
SuperJapSpeed's Avatar
I took my governor off today and it worked and the CEL didn't come on but my car is idling a little rough
Old Apr 7, 2005 | 07:34 PM
cel will eventually come on
Old Apr 8, 2005 | 10:03 AM
Now my car is almost stalling whenever i slow down in neutral so i raised the idle to 1,000 rpm but i want to be able to put it back to normal without it almost stalling all the time. I was going on an offramp today and i actually did stall on the offramp and i lost power everything and almost hit the wall.
Old Apr 8, 2005 | 10:21 AM
mzmtg's Avatar
...then that wasn't the speed sensor wire you cut...
Old Apr 8, 2005 | 04:21 PM
yeah you def. clipped the wrong wire!
Old Apr 8, 2005 | 06:44 PM
Supermax95's Avatar
when my speed sensor went bad and my cel light came on my car started idling rough and stalling...
Old Apr 8, 2005 | 07:47 PM
it was definitly the speed wire and im pretty sure my battery is dead cuz now my car won't start unless i pop start it or jump it that could have been the problem all along and i might just be paranoid
Old Apr 10, 2005 | 07:48 AM
when u cut the speed limiter wire to u just tape it off or is there anythin else u do to it
Old Apr 11, 2005 | 06:20 AM
put a toggle switch on to eliminate the cel and be able to go over 120mph w/ the flik of the switch.
Old Apr 11, 2005 | 09:09 AM
yea i might be retarded but idk wut a toggle switch is or how to install one but i am very interested in doing it
Old Apr 11, 2005 | 07:14 PM
go to autozone and ask for a 2 terminal toggle switch. if you pay more than $5 you got ripped off. cut the speed sensor wire and solder a wire to each end of where you cut the wire. run both wires to your toggle switch. when the toggle switch is in the on position your speed sensor is fully fuctional and being monitored by the ecu. when you flick the switch off your ecu will not be able to monitor the speed sensor and will therefore be able to go as fast as the car will take you.
Old Apr 11, 2005 | 07:18 PM
sweet thanks ill do thats **** first thing tomorrow
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
