What are Glazed Brake Pads
Old Apr 7, 2005 | 07:39 AM
Kinger402's Avatar
I heard someone use the term Glazed Brake Pads. How does this happen to your brake pads, What are the symptoms that your pads have become glazed. Thanks for the education
Old Apr 7, 2005 | 07:40 AM
mzmtg's Avatar
Minister of Silly Walks
google?....
Old Apr 7, 2005 | 07:42 AM
NmexMAX's Avatar
dot dot dot ...
Think of your face after falling flat on a basketball court sliding face first...
Old Apr 7, 2005 | 10:30 AM
AlexI30's Avatar
Glazed pads refers to the fact that the abrasives on your brake pads has worn out and is dull, therefore reducing your braking efficiency. This could be fixed by passing an abrasive stick on your pads and removing the old abrasives to expose fresh ones, this is supposed to happen on its own usually, but it doesnt always.. You can tell if this is the case by looking at your pads and seeing if it looks "glazed" and shiny.
Or you could just buy new ones....
Old Apr 7, 2005 | 10:33 AM
MDeezy's Avatar
Glazed Brake Pads sound like a pastrie.
Old Apr 7, 2005 | 10:36 AM
nd4spdgt's Avatar
I'm actually need to get some new pads and rotors myself, what's recommended as far as pads/rotors go? I need new pads all around and new rotors for the front.
Old Apr 7, 2005 | 10:39 AM
MDeezy's Avatar
I think hands down no one can complain about OEM Pads being a good replacement. as for Rotots I've heard some good things about the Brembo Blanks.
Old Apr 7, 2005 | 03:01 PM
ThisMaxIsTight's Avatar
yes MDeezy, you are right...I definitely agree with you...Brembo rotors are GREAT cause there much cheaper than OEM rotors and OEM pads are the best since there is no squeaking and medium dust and offcourse made of a high quality material...
Old Apr 7, 2005 | 07:13 PM
Magikone69's Avatar
i hear mentioning of glazing is also caused when you do a hard stop and a thin layer of glass is created on the brake pad and rotor, is this similar or am i jus completely off.
Old Apr 7, 2005 | 08:45 PM
NmexMAX's Avatar
dot dot dot ...
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
