Old, Busted Dust Boots
Old May 8, 2001 | 03:58 PM
deezo's Avatar
Problem, my dust boots are gone. How crucial is it that I go through the summer with them in the busted shape they are in? Thanks in advance.
Old May 8, 2001 | 04:05 PM
Daniel B. Martin's Avatar
What do you mean by "dust boots"? Are you referring to the Constant Velocity joint boots? If so, that must be repaired immediately. If they have been "gone" for a while it may be too late to save your CV joints.
Old May 8, 2001 | 04:32 PM
deezo's Avatar
Just when I think I am giving all of the information, my mind wanders. I meant the shock boots.
Old May 8, 2001 | 04:50 PM
Eric L.'s Avatar
Well, the dust boots keep the shaft of the struts clean and free from road dirt and grime. If your boots are torn, the shock will get dirty and MAY fail prematurely. Unfortunately replacement of the dust boots is very labor intensive, and involves disassembling the entire front strut assembly for replacement. So, if you feel the itch, I would do some suspension upgrades at the same time to save on labor costs.
Old May 8, 2001 | 06:30 PM
deezo's Avatar
I agree. I'll let them wear out then.
Old May 8, 2001 | 09:54 PM
OgreDave's Avatar
Theyre also like 50 bucks a pop. Ive asked.. anyways, konis have lifetime warranty. bahhaha bring it on.
Old May 9, 2001 | 12:23 AM
Eric L.'s Avatar
The lifetime warranty on shocks and struts are dependent on other factors, such as functional dust boots. Read your warranty carefully, it will probably say that the warranty is void if the strut or shock is not taken care of properly (i.e. has a intact dust boot).
It's kind of like the engine warranty. If you don't change your oil and the engine breaks down, then the warranty is void due to the owner's negligence. Same thing with dust boots.
Old May 9, 2001 | 12:38 AM
Stillnmax's Avatar
where would one purchase Dust boots.
Old May 9, 2001 | 01:13 AM
Eric L.'s Avatar
From the dealer. Shouldn't be too expensive.
Old May 9, 2001 | 06:22 AM
sinewave's Avatar
I changed the dust boots when I installed new struts and springs. IIRC, the fronts were $11 each and the rears were $18 each. That was from Courtesy Nissan, my local dealer wanted 25% more.
I've heard some have gone to an off-road shop and bought some aftermarket boots, then trimmed to fit.
Old May 9, 2001 | 06:27 AM
deezo's Avatar
That will work too. Aftermarket struts don't come with boots?
Old May 12, 2001 | 06:49 AM
sinewave's Avatar
The Eibach's that I bought didn't have them. I don't know about the other brands.
Old May 12, 2001 | 11:36 AM
Don in Texas's Avatar
Eibach makes Struts? I didn't know that....
Just leave the boots alone, it won't hurt anything
Old May 12, 2001 | 11:41 AM
Gary95's Avatar
takin' care of boots
I was wondering about this... if you periodically "armorall" your CV joint boots, dust boots, and other rubber fittings exposed to the elements, will it significantly extend their life? Or will the life extension be insignificant?
Old May 12, 2001 | 01:09 PM
spyder
haha Armor all .... ok here is the deal with them and other Rubber shiner thingies .... if they have any silicates or Silicone products they will turn the rubber brown! thats right brown... Just leave the boots alone , they dont get too dirty unless you take your 4x4 maxima off roading.
Old May 13, 2001 | 04:50 AM
sinewave's Avatar
Sorry, I had a brain fart; I meant to say Tokico's.
Old May 14, 2001 | 06:45 PM
deezo's Avatar
Thanks people. I am going to wear the struts out before I do anything. The car still rides lovely.
Old May 14, 2001 | 08:57 PM
OgreDave's Avatar
at which point ill buy dust boots and say i had them on!
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
londonflu
Sep 19, 2015 02:33 PM
