Questions on intake...
Final direction question, please chip in on your thoughts:
I purchased an ebay CAI (in fender) about 6 months ago, am now at the point to install a 'Y' along with either the CAI or a hacked airbox, wondering which intake solution has the least downside. I have heard that a CAI install has great sound but can lead to low-end loss, does the hacked airbox have any performance drawbacks? Is the sound similar? Please comment if you have experience with either setup. Thanks!
so you're going to either keep the cai or use a hacked air box and put a "y" in it to ad some additional type of filtering?
If thats the case, i wouldnt do it, it would just be money thats wasted, however if you just want to be different then wth go for it
The loss on the CAI is at the high end. If high-end is critical for you, then go with the hacked setup and do your own cool air setup. You can use the pipe from the CAI itself, you might have to cut down the pipe a bit. Use a silicon reducer and cut a 2" hole on the side of the air box. Then connect the CAI pipe with the hole you just cut. Then the other end of the CAI pipe will go thru the usual hole that you will be cutting out of the metal surface next to the battery plate. And there you go, CAI w/o high-end loss. Add the Y pipe and you'll have a kick-*** setup.
BTW, which CAI did you get from ebay?
They have the cool air scoop from the factory but most people ditch them. I did mine before but I'm putting it back. But that scoop does very little for directing cool air into the intake however, little is better than nothing IMO.
Originally Posted by Dooley
Do all 4th gens have the ram-air design that has the scoop design on top of the grille?
heh, i like my CAI, but its no cheapy. Bought it new from Cattman performance.
but, anyway, puddles wont hurt anything at all, you just cant drive through water that will completely submerse the end of the CAI. this is when hydrolock occurs.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
