Car is dead, no lights, no horn, no sound when starting
Old Apr 13, 2005 | 01:39 PM
rwatt1981's Avatar
Ok, my car's electrical system is shutdown. nothing works at all. my dad tried jumping it with booster cables and nothing happened. no sound or nothing turning over. for the past few weeks, whenever i tried to start it cold, it would make a funny sound, like a squeel sound. when it would start up, i would have to press the gas in order for it to start up, if not, it would bog down and die. so does anyone know what my next step would be? thanks!
Old Apr 13, 2005 | 01:43 PM
icedout's Avatar
could be the starter,my friend and his sentra just went threw this or maybe your battery is completly dead...
Old Apr 13, 2005 | 02:33 PM
2 Da Max's Avatar
hhm sounds like starter, but the boggin down issue is because you need to clean your tb, and iacv. it used to happen to me in the cold
Old Apr 13, 2005 | 02:34 PM
Ant96GLE's Avatar
For one, the battery is completely dead. Just a boost wont start it. The battery will need to be charged. I would start with charging the battery or getting a new one. Second will be getting the alternator checked to see if it is putting out the voltage it should be putting out.
Old Apr 13, 2005 | 05:27 PM
Ruiner6's Avatar
a sensor could be bad, u might wanna check that possibility out
Old Apr 13, 2005 | 05:28 PM
rwatt1981's Avatar
The result was the battery was completely dead. Went to VIP and bought a battery and it fired right up. Once the weather starts getting warmer up here, I will be cleaning out the TB and other misc things aswell. Time for a tuneup this spring. Thanks guys!
Old Apr 13, 2005 | 05:47 PM
Loe max's Avatar
Umm....did you check your alternator also?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Jcof88
Aug 3, 2015 10:43 PM
