alignment
No you dont need it checked. There's nothing to adjust. Even if you removed the strut.
The only thing adjustable on our cars is the Toe In. That's altered only if you mess with the tie rod ends or change the rack and pinion
Originally Posted by ed zachary
Obviously, everybody's got an opinion, but I have my alignment checked any time the front end gets worked on, except for the brakes.
If you get an alignment, there's nothing to adjust except toe. Anyone who says you need an alignment on a Maxima after a strut change is stealing your money.
You MAY need one after ball joints. Definitely need one after you work on the steering.
If you think i'm wrong and this is my opinion thats fine. I'll open up a maxima alignment shop and charge $50 to put cars on a lift.
Originally Posted by PAREDLINE
It's not an opinion. It's fact.
take it from a guy who works on cars for a living...anytime the front end is worked on you need an alignment. there is also camber that needs adjusted. if you have aftermarket struts then the camber will not be the same when you bolt the front end back together unless you mark the strut. even if you dont have aftermarket struts if the bolt holes have been grinded out to adjust camber into spec or for handling purposes then you will need an alignment. i like my toe dead at 0 degrees and my camber around -.40 or so. a little negative camber equalls better handling. if the guy isnt adjusting camber and toe then he is stealing your money but if he does it the right way then its worth it.
Good matchmarking of these bolts generally saves the need for a realignment if you're not changing any of the parts (i.e. axle work), but still doesn't guarantee it. I say, if you're going to drive significant miles after working with the front end, always get the alignment checked.
Dave
Originally Posted by larryseibel
take it from a guy who works on cars for a living...anytime the front end is worked on you need an alignment. there is also camber that needs adjusted. if you have aftermarket struts then the camber will not be the same when you bolt the front end back together unless you mark the strut. even if you dont have aftermarket struts if the bolt holes have been grinded out to adjust camber into spec or for handling purposes then you will need an alignment. if the guy isnt adjusting camber and toe then he is stealing your money but if he does it the right way then its worth it.
And if the struts are a good brand and built to spec, there will be no alignment necessary.
When you go to firestone/sears/midas for an alignment I will bet you anything that 90% of them do not even know how to do a camber alignment on a maxima.
Exactly. I agree with you. How many alignment shops do you think actually grind strut holes so your camber is in line? For 59.99?
My struts are Tokicos - quality IMO - and yes it is imperative that the camber still be checked since 1) it is not a precision machined component and 2) the bolt holes have some clearance. I wouldn't want a perfectly drilled strut or else I'd never get the damn thing together.
If there is any discussion here, it should be over if that 1 degree of camber adjustment is significant for a daily driver. And the answer is 'maybe'. But given that I prefer to use higher performance tires which wear out faster, I want it exactly in spec. I imagine most people on this board have similar interests and would want it in spec as well.
Dave
NewMax03
Oct 7, 2015 08:27 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
