Removing Exterior Pin Stripe
Old Apr 14, 2005 | 10:29 AM
Kinger402's Avatar
What is the best way to remove the ugly-@$$ pinstripe on our cars
Old Apr 14, 2005 | 11:10 AM
NmexMAX's Avatar
dot dot dot ...
http://www.forums.maxima.org/showthread.php?t=392745
If yours is older like a 95, then you might want to leave it on because the paint under there hasn't seen what the other paint has, meaning you'll have a strip of practically new paint and the res of the car will have a 10 yr old paintjob ..
Old Apr 14, 2005 | 12:36 PM
Kinger402's Avatar
Blowdryer and a plastic spatula..is a great idea....i dont think the paint difference will be that noticable...but we will see
Old Apr 14, 2005 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
Mine was noticeable 5 years ago, and the car was only 5yers old at the time, not sure about RI, but here in NM, the sun is brutal. Also why when body shops try and match paint, they have a special rule relative to a cars age required for the paint mixing to match stock parts if the whole car isn't getting painted.
Old Apr 14, 2005 | 02:01 PM
mad wayz's Avatar
yeah heat gun worked
Old Apr 14, 2005 | 02:11 PM
Dave H.'s Avatar
I used a hair dryer, on low, and just started peelin it off. Took some time, but it was well worth it. It did leave a noticeable mark, but that goes away after a while. Good luck...
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
