Cold Start Problems
Old Apr 18, 2005 | 10:08 AM
XeroX's Avatar
Hella internets
Cold Start Problems
I replaced my Coolant Temp. Sensor cause i pulled up a code for it about 2 weeks ago.
Before i changed the temp sensor, my idle in the morning would be pretty wierd, like it would rev up to 1500~ and instead of holding it there till it would warm up it would drop all the way to 800~ and then slowly raise back up to around 1300~
After replacing it i thought this would be fixed...but its still doing it! Not as bad tho, but it still doesnt go back to normal and cold start like it used to...
Any ideas?
Old Apr 18, 2005 | 10:14 AM
Bobo's Avatar
Have you cleaned your idle air control valve (IACV)?
Old Apr 18, 2005 | 10:42 AM
XeroX's Avatar
Hella internets
i did about 3-5k miles ago. I doubt its gotten that dirty...
Old Apr 18, 2005 | 10:43 AM
XeroX's Avatar
Hella internets
Hmm.. i was thinking would a MINOR vacum leak in the IACV cause this? I remember when i cleaned the IACV that i reused the old gasket and it had a small crack in it that kinda just put back together....But i cant hear any leaks...but could this be the problem?
Post up some more ideas tho, cause i doubt its that... lol
Old Apr 18, 2005 | 11:26 AM
Bobo's Avatar
Vacuum leaks are a major contributor to rough/surging idle on many cars. It could possibly be the culprit.
Old Apr 18, 2005 | 11:29 AM
Jeff92se's Avatar
I'm needing a caw
yes it can. You can try to cheat by putting some gasket sealer on both sides. But these gaskets are petty cheap. I'd just buy a new one
Old Apr 18, 2005 | 11:30 AM
XeroX's Avatar
Hella internets
yea...but ive checked and listend for leaks in that area, and found nothing...
is there anything else that could cause this?
Old Apr 18, 2005 | 11:32 AM
Jeff92se's Avatar
I'm needing a caw
Try spraying with wd40 and listening for a higher idle?
Old Apr 18, 2005 | 11:36 AM
Bobo's Avatar
You could be there for the rest of your life and not hear a vacuum leak.
Old Apr 18, 2005 | 12:26 PM
njmaxseltd's Avatar
Check the operation and adjustment of the fast idle plunger and cam linkage.
The Haynes shop manual is your friend.
Old Apr 18, 2005 | 12:32 PM
XeroX's Avatar
Hella internets
Hmm....Not the most literate person, but im guessing this involves inspecting the timing chain and all those parts around there? Cause i do need to replace the top tensioner closest to the passenger side, it clacks durring warmup/cold start in the morning, but not while driving...Could this also be a cause to my problem?
(damn, this post is making my max look like POS haha)
Old Apr 18, 2005 | 12:33 PM
Jeff92se's Avatar
I'm needing a caw
We could be here longer before you post some legitimate information too
Old Apr 18, 2005 | 12:35 PM
Jeff92se's Avatar
I'm needing a caw
Read this and dig around the repair manual. Covers VQ30 also.
http://www1.autozone.com/servlet/UiB...3d801f4ea5.jsp
Old Apr 18, 2005 | 12:38 PM
Bobo's Avatar
I commented on the possibility of the vacuum leak being the culprit and suggested subsequent to that that he might not hear it. That was the recent experience I had on my other car, which is not a Maxima. Not being the mechanical genius that you are Jeff92SE that's the best I can come up. Sorry to disappoint you, but I won't lose any sleep over it.
Old Apr 18, 2005 | 12:40 PM
Jeff92se's Avatar
I'm needing a caw
Well since he ALREADY mentioned not hearing anything, I fail to see why you restated the obvious. If you aren't a mechcanical genius or don't know how to fix this guy's problem, why post??? You and Amelius related?
j/k. you helped in the first reply....
Old Apr 18, 2005 | 12:55 PM
Bobo's Avatar
All I was suggesting was that because he couldn't hear a vacuum leak, it doesn't mean there isn't one. I couldn't hear the vacuum leak on my RX7 either but it was the culprit in my idle being all over the map despite the TPS being adjusted 17 ways from Sunday. I guess I should limit my mechanical skills to filling my gas tank and checking my oil. I'm good at that.
And no I am not related to Armelius. I haven't seen many postings from him of late and am somewhat disappointed because I wait for them with bated breath. Well, I guess mrgreek's insights will have to suffice in a pinch, lol. As you can tell, I'm easily amused.
Old Apr 18, 2005 | 12:57 PM
Jeff92se's Avatar
I'm needing a caw
I can still read your deleted post.
Old Apr 18, 2005 | 01:00 PM
Bobo's Avatar
I elected to delete it after I noticed you edited yours.
Truce?
Old Apr 18, 2005 | 01:05 PM
Jeff92se's Avatar
I'm needing a caw
But okay....
Truce?
Old Apr 18, 2005 | 01:11 PM
Bobo's Avatar
Good. If you continue to be nice to me I'll tell you where the good Chinese restaurants are in Richmond.
Old Apr 18, 2005 | 02:32 PM
njmaxseltd's Avatar
The fast idle control is on the throttle body. The plunger that controls it is down on the lower left side, under the linkage. There is a cam and follower that opens the throttle slightly when your engine is cold. There is actually a scribe mark on the cam that needs to line up with another scribe mark on the follower at a specific temperature. (cold engine) The item that could fail is the plunger. It's not sold seperately either, if it's bad you have to replace the throttle body.
Old Apr 18, 2005 | 02:43 PM
XeroX's Avatar
Hella internets
Hmmm, im gona have to take a look at this one, i cant really c where this thing is at (in my head). Im gona check out that link jeff posted, maybe that will help me figure out what your talking about...
Old Apr 18, 2005 | 02:45 PM
Jeff92se's Avatar
I'm needing a caw
Much easier to see vs describe. That's for sure.
Old Apr 18, 2005 | 02:48 PM
XeroX's Avatar
Hella internets
Oh!, wait up...Is this fast idle control where the throttle cables attach? Its kinda like a lil screw that you can adjust?
Old Apr 18, 2005 | 02:49 PM
XeroX's Avatar
Hella internets
where the cables attach to the throttle body, throttle control or whatever the hell its called haha (im not talking about the idle adjustment screw on the IACV)
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
FlaMark
Aug 21, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
