Small accident. need some help.
Old Apr 18, 2005 | 05:51 PM
Kolyan's Avatar
i hit a curb with a front wheel sideways a month ago and since then i cannot get rid off the vibration at highway speeds (60+). i changed the wheel and i road forced all 4 but vibration is still there. what could've i damaged? btw. the vibration is excessive.
thanks
Old Apr 18, 2005 | 06:06 PM
YozhiksMax's Avatar
you might need an alignment on all tires....
Old Apr 18, 2005 | 06:09 PM
kormax97
yup.. just alignment
Old Apr 18, 2005 | 06:10 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
Check all your front suspention components. Axle, tie rod, struts, etc.. Also, you could have knocked the wheel weights off. I would do the cheaper things first. i.e, wheel balance, then alignment, then front end pieces. Good luck.
Old Apr 18, 2005 | 06:14 PM
Blue96Max's Avatar
sbddude took all da werds out dats wat it is man
Old Apr 18, 2005 | 06:37 PM
njmaxseltd's Avatar
If you hit a curb hard enough to bend a wheel you should have also replaced the hub and bearing.
Alignment issues do not cause vibrations.
Something is loose, bent or out of balance. Check your tie rods, both the inner and outter joints. Check your lower control arm & ball joint. Check your CV joints for play.
Old Apr 18, 2005 | 06:40 PM
pavelsmax's Avatar
theres your answer i bent a rim this summer on a curb
i had to replace my hub and tie rod... and the rim of course
then get it aligned just for good measure... as alignment has no effect on vibration
Old Apr 18, 2005 | 10:24 PM
Kolyan's Avatar
Alignment done. Road Force done (balanced all 4 wheels, rims good, tires good) i did replace one wheel. If the problem is hub and tie rod, how much will it cost me?
Old Apr 18, 2005 | 10:56 PM
SpeedyMaxima's Avatar
See if the axle is ok or control arm
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
