how do i know if rear calipers are to blame for bad braking?
Old Apr 18, 2005 | 06:14 PM
gold4thgen's Avatar
my rear brakes look bad all maxes have the whole disk silver because the whole pad is been used but mines look fine in the inner part but in the outer they look corroded with like rust glazed on the rotors and when im going fast my brakes suck, my sisters honda accord brakes way better and hondas have alway been know for crappy brakes. and my pads look thick not worn from the outside......any suggestion, im doing my brakes soon with rotors and pads so i want to know if i need calipers too...
Old Apr 18, 2005 | 06:27 PM
joeeey's Avatar
From what your describing it sounds like you caliper slide pins are frozen. Remove the calipers, Then remove the slide pins clean it out with brake cleaner the use a high temp grease
Old Apr 18, 2005 | 06:31 PM
Black Maxima
My brakes just suck to begin with. I have to press the pedal down real far to stop. It isn't fun to drive. My mom's 2000 GXE has some real nice, sensative brakes. I want to check if I have any air bubbles in my lines.
Atleast they look cool...
Aaron
Old Apr 19, 2005 | 12:17 PM
dki378's Avatar
What did you use to paint your calipers? I like.
Old Apr 19, 2005 | 01:42 PM
Black Maxima
I used high temp (500 degree) engine spray paint. The color is "Ford Red" and I bought it at AutoZone. I didn't spray the paint on, I used a paint brush. I sprayed the paint into a cup and used it that way.
My brakes still suck B@llz...
Old Apr 21, 2005 | 06:19 AM
Sounbwoy's Avatar
[QUOTE=Black Maxima]My brakes just suck to begin with. I have to press the pedal down real far to stop. It isn't fun to drive. My mom's 2000 GXE has some real nice, sensative brakes. I want to check if I have any air bubbles in my lines.
when is the last time you actually CHANGED the brake fluid? Don't forget, brake fluid is HYGROSCOPIC which means it absorbs water. The longer you go without changing it, the less effective it will be over time. FLUSH everything, and make sure you have no leaks as well. Check the level of your brake pads as well, b/c obviously, as they wear, the more pedal travel is required..
Old Apr 21, 2005 | 08:41 AM
Black Maxima
This is what happend. I bought the Maxima and brought it to the dealer for all new pad, rotors, and calipers in the rear. They also bled the brake system. When I got the car back I noticed I had to push the pedal down farther than before. I told that to my dad and he test drove the car. He said that it wasn't really a problem. But, obviously there is since my mom's 2000 GXE has really sensative brakes and there is a BIG difference. My dad's 2002 Toyota Sequioa can stop faster and easier than my car.
So, I guess my next step would probably be to change the brake fluid. I checked the brake fluid thing and it is right under FULL. I don't suspect any leaks along the lines either.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
RealityCheck
Aug 5, 2015 06:18 AM
