rotor width tolerance
Old May 10, 2001 | 11:48 AM
danielbu's Avatar
What are the tolerances for rotor width on the stock rotors?
Thanks,
dan
Old May 10, 2001 | 12:19 PM
Chunger's Avatar
My other car is a Hybrid
It should be imprinted on rotor itself... either on the outer diameter or on the inside face...
If you've never turned the rotors before, you shouldn't have problems turning it at least 2-3 times... depending how much was taken off each time on the Lathe..
Old May 10, 2001 | 03:09 PM
Daniel B. Martin's Avatar
Originally posted by danielbu
What are the tolerances for rotor width on the stock rotors? ...
Front rotor, minimum thickness 20mm.
Rear rotor, minimum thickness 8mm.
Front rotor, maximum thickness variation 0.01mm.
Rear rotor, maximum thickness variation 0.02mm.
Old May 10, 2001 | 05:06 PM
danielbu's Avatar
Thanks for the specs Dan, now to find some verniers.
Regards,
Dan
Old May 10, 2001 | 06:03 PM
Use a micrometer
Thanks for the specs Dan, now to find some verniers. ...
Vernier calipers are not the right measuring tool because of the rust ridge at the periphery of the rotor. Use a micrometer. See Chilton (page 9-11) or Haynes (page 9-10).
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
