Left rear is 2" higher than right rear???
Old Apr 20, 2005 | 04:50 PM
PoePoe2797's Avatar
I've noticed I've been having suspension problems for a few weeks now. But today I was approaching my car it it looked like it was sitting crooked. Sure enough I got my tape measure, measure both sides and got a 2" difference. Theres definatly gotta be something wrong. What are the possiblities to look at?
Old Apr 20, 2005 | 04:53 PM
njmaxseltd's Avatar
Broken spring?
I find it hard to believe you have a 2" differance, thats pretty extream.
Were you on a level surface and sober when you measured?
Where did you measure from/to?
Old Apr 20, 2005 | 04:58 PM
PoePoe2797's Avatar
Well it was about 5cm, which is about 2" .....extreme or not, thats the way it is, I swear. I measure a couple ways, from the ground to top of the wheel well, measured the tires (same, maybe +-0.5cm), and measured from the ground to the corner rear bumper lines. What would be the driving symptoms of a broken spring?
Old Apr 20, 2005 | 05:00 PM
PAREDLINE's Avatar
turn your car around and see if it's still 2 inches
Old Apr 20, 2005 | 05:27 PM
Ant96GLE's Avatar
Yes 2" is quite extreme... Do you have any creaking or groaning noises? The spring could've broken, jumped, the car could've fallen off the ball joint?
Old Apr 20, 2005 | 05:51 PM
PandaXpress's Avatar
two inches? make sure that your on a flat surface thats not angled at all.
Old Apr 20, 2005 | 05:57 PM
Ant96GLE's Avatar
Maybe you measured it last night after a few cocktails and didnt notice half the car was on the curb??
Old Apr 20, 2005 | 06:20 PM
PoePoe2797's Avatar
Listen, the car its 2 inches, yes......it does have groaning and creaking. And I was under the impression that rear doesnt have ball joints. I posted the other day how when I go over bumps, the rear end want to slide out to the right also, might have something to do with it. Enough with the drunk talk
Old Apr 20, 2005 | 07:02 PM
nismos14's Avatar
§è~® f®ÈÄk
remove the wheel and have a look at everything or take it to a shop thats the only way anything will get done
Old Apr 20, 2005 | 07:10 PM
PoePoe2797's Avatar
Thats wha Im asking though, what should I look at?
Old Apr 20, 2005 | 08:04 PM
MDeezy's Avatar
and fluids leaking from the shock, do the shock test cause it sounds blown.
most likely you'll looking at replacing.
Old Apr 20, 2005 | 08:31 PM
PoePoe2797's Avatar
Thanks, Ill take a look tommorow afternoon and report back
Old Apr 21, 2005 | 09:48 AM
HomerMAC's Avatar
Donating i30 Owner
push down on the lowered end.. and let go.. if it jumps back up... and keeps moving ur riding on springs... it it doesnt go down.. ur ****ed.. look to wehre the springs mett the mount.. next ot tire. it is off the "groove"
i saw a old guy driving a max few days ago.. and the front strut spring was almost completely off the mount form underneath.. ofcourse being the nice person i am.. i pulled up.. and being in my work outfit with the lab jacket and all.. he opened his window.. and listend to teh advice..
another fellow max saved.. yay! for me...
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
doctorpullit
Sep 10, 2015 06:33 PM
