Cylinder 1 Misfire
Old Apr 22, 2005 | 07:37 PM
lanky2882's Avatar
Cylinder 1 Misfire
Im throwing a cylinder 1 misfire code. IS there a diagram for what cylinder is cylinder 1 and what could be causing it
Old Apr 22, 2005 | 09:06 PM
meanbean's Avatar
Here is a pic of the cylinder location per reference number. A cylinder misfire means that your ignition coil or spark plug for that cylinder may need to be replaced.
Old Apr 22, 2005 | 09:31 PM
asheep's Avatar
where can i get the ignition coil for cheap on the internet?
lowest i can find is around 60 bucks for the Mitsubishi ones
thanks in advance
Old Apr 22, 2005 | 10:33 PM
lanky2882's Avatar
I replaced the coil still misfiring spark plugs are knew but gonna pull it out and check
Old Apr 23, 2005 | 08:57 AM
TheFink's Avatar
I had to get some coils replaced becuse I thought that i had the same problem not to long ago. I was told it was due to the fact that one side of the engine wares on them harder than the other. after she was fixed it ran great again.
Old Apr 23, 2005 | 09:02 AM
Jatan's Avatar
Reset your CEL and swap the coil pack from cylinder 1 with cylinder 5. Now if you get a cylinder 5 code, it's the coil pack. If the code stays at cylinder 1 then it's the fuel injector. Is the spark plug fine? You can try this: http://forums.maxima.org/showthread.php?t=389309
Old Apr 23, 2005 | 11:27 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Fuel Injector Shot. Replace it before you have to replace your Catalitic Converter.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
