~Strange tranmission whining?? (5 speed)~
Old Apr 22, 2005 | 11:51 PM
LudeAEM's Avatar
My friend has a 98 Se 5 speed and while in gear (mainly first and second) it makes a whining noise which is dependent on engine RPM. It has nothing to do with the motor because i would push the clutch in and rev to make sure it wasn't coming from the motor. What could this be? Throw-out bearing bad? Bad sinchros? Anyone have any problems like these?
Old Apr 23, 2005 | 01:06 AM
nadir_s's Avatar
vicodin ... gift of life
bad differential bearings ...
how many miles?
eventually, the whining will spread into all 5 gears and you will notice a tranny fluid leak coming from the driver side axle.
Old Apr 23, 2005 | 11:34 AM
ChristheNite
yeap, like he said above - same thing happened to me, faint whine that got progressively louder and then spread through all the gears - my suggestion: get on car-parts.com and look for a used 5th gen trans. and swap it before it gets worse.
Old Apr 23, 2005 | 11:38 AM
LudeAEM's Avatar
ok thanks for the input
Old Apr 25, 2005 | 05:49 AM
amb4081's Avatar
How quickly will the spreading take place? Because I have had the whining noise primarily in 1st and second since I've owned the car (2000). I can't say it has gotten much worse. At time of purchase in 2000, it had 46K miles. Now, it has 95K miles.
Old Apr 25, 2005 | 09:51 AM
dayglo's Avatar
yeah.. mine too
hasnt gotten worse but still whines in 1st
i assumed it was just the previous owner engine braking into 1st or just bagging on the poor gear in general.
i have a trani leak coming from the gear housing, nothing from the drivers side axle
Old Apr 25, 2005 | 10:45 AM
amb4081's Avatar
Ditto for me with the leak too. It is so slow a leak I only check it once a year and only have to top it off every 1 1/2 or 2 years.
Old Apr 25, 2005 | 11:18 AM
MienMaxima's Avatar
Last time I heard a whine in my car like that my alternator blew out. There was literally smoke coming from it. Luckily, there are recalls on them and got it replaced for free. Towing and everything.
Old Apr 25, 2005 | 03:48 PM
LudeAEM's Avatar
It only does it when its in gear. If it was the alternator it would while in every gear and in nuetral when you rev it. It didn't do that though.
Old Apr 25, 2005 | 04:39 PM
nadir_s's Avatar
yeah ... if the whining sound is in first and 2nd gear and you have some leaking ... i woudln't suggest to just jump and change your tranny. It's not like your tranny will explode on you on the free way or anything. I drove with bad differentials all the way till the whining spread to 5th gear (10-15k mi). The leak didn't get any worse than it was since the beginning ... on and off - especially leaked when the car was driven for a long time... and the smell of tranny fluid on a hot day sucked.
just save up money .. i suggest you keep an eye out for a 5th gen 5-spd tranny and go from there, or just rebuild your tranny and cross your fingers the problem doesn't happen again.
Old May 25, 2005 | 12:15 PM
thatoneguy's Avatar
my car does the same thing
Old May 25, 2005 | 01:05 PM
nismos14's Avatar
§è~® f®ÈÄk
It could also be a throw out bearing, or input shaft bering, or main bearing, you have to keep in mind, someone who is there (a mechanic) and can actually hear the sound and test w/ pressing the clutch in and letting it out is going to be able to give you the best answers
Old May 25, 2005 | 01:07 PM
Brudaddy's Avatar
I also have a 99 SE-L that makes kind of a whine in 1st and 2nd. I think mine is attributed to the alternator or air compressor, because it is only really noticeable when the air is on.
I don't know if it could be that on yours, but check that out too.
Good luck.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
