how to paint mud guards body color?
Old Apr 28, 2005 | 05:39 PM
chillin014's Avatar
I have a "rosewood" 95 GLE, i want to paint my mud guards behind the wheels the color of the body and i was just wondering how to go about this.
if this is in the stickies forgive me, i dont remember seeing it.
what im asking is, how to paint it, what paint to use, and what enamel to use. and should i sand it?
i dont know anything about the procedure obviously so help is appreciated
thanks.
Old Apr 28, 2005 | 05:43 PM
MDeezy's Avatar
This is new I havent seen max with painted mud guards. I'm sure it will get a lot of rock and such scratch it up as thats what mudflaps are there for but I'd like to see it still.
if you can find a duplicolor paint, clear coat, and I'm not sure how you'd prep such a surface. I'd want to say sand prime and then paint but I know such a surface with need a specific type of primer, hopefully someone will jump in with what kind you need.
Old Apr 28, 2005 | 05:46 PM
chillin014's Avatar
you havent?? ive seen a couple on the org.
Old Apr 28, 2005 | 05:50 PM
MDeezy's Avatar
they look good and shinny like clear coat was used?
Old Apr 28, 2005 | 05:51 PM
chillin014's Avatar
man i saw one like 2 SECONDS AGO i thought it was on the windsheild tint thread but i can NOT find it now. i think it was pretty shiney
Old Apr 28, 2005 | 05:52 PM
joeeey's Avatar
I'm sure you paint it the same way you paint a urathane body kit. You gotta sand it,add a flex additive, color then clear
Old Apr 28, 2005 | 05:54 PM
chillin014's Avatar
what is a flex additive? and waht kind of sand paper? i need specifics or im pretty lost. Also, how do i get my body paint color?
Old Apr 28, 2005 | 06:01 PM
joeeey's Avatar
I own a repair shop and my partner owns a body shop ( in the same building ) So I see alot of repairs done there. So I'm gonna try to explain it as best as I could. First off I'm not sure if you can by the flex in a spray can. The body shop uses it in a spray gun. ok I would sand it with 300 dry, just to remove any imperfections. Then 600 wet ( with water ) to smooth it out. spray flex additive then color then 3 light even coats of clear. giving time between coats of clear. I sould be on the money but if not someone correct me. I'm a mechanic not a body guy. As far as getting the paint in your color. Humm in a body shop they mix it, but I'm sure you can find some dupli color match in a pep boys or autozone.
Old Apr 28, 2005 | 06:03 PM
joeeey's Avatar
the color goes by the color code which I belive is in the drivers side door jamb on the decal which says EXT and a letter/ number set below it
Old Apr 28, 2005 | 06:05 PM
chillin014's Avatar
thank you, i know the code deal i just dont know how i would get the paint.
Old Apr 28, 2005 | 06:06 PM
joeeey's Avatar
your color code should be LS5 ROSEWOOD
Old Apr 28, 2005 | 06:07 PM
joeeey's Avatar
they sell color matched paint in pepboys, autozone, r & s strauss. it's made bya company called dulpi color. They have a color with your exact code
Old Apr 28, 2005 | 06:14 PM
chillin014's Avatar
i'll look tomorrow, thank you for your help
bumpypickle
Sep 20, 2015 08:22 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
mclasser
Sep 6, 2015 09:05 AM
