Weird problem
Old Apr 29, 2005 | 11:54 AM
DonOfDesperados's Avatar
Weird problem
Not sure what it is but i know its not batt, alt, starter, plugs or belts. but my damn car wont start when i crank it unless i feed it gas while turning the key. If i dont feed it gas it just cranks and cranks and turn and turn. Anyone have any advice? would be much appreciated
Old Apr 29, 2005 | 01:02 PM
Akumachan's Avatar
I never narc'd on nobody.
IACV? TB? if you gotta "give it gas" which is really giving it air, then something must be up with intake.
Old Apr 29, 2005 | 02:56 PM
whats AICV and TB? Anyway I can test it
Old Apr 29, 2005 | 03:35 PM
VeN0m's Avatar
Check the ignition switch under your steering column, mine had burn marks where it shorted out due to crappy soldering when cranking, even had a battery blow up in my face. The new ones solder points are spread MUCH farther apart. It's only 20-30$ (and yes I had to give mine gas too) now it starts up as soon as the key is turned.
Old Apr 29, 2005 | 04:08 PM
PAREDLINE's Avatar
Yeah check if you have a good start signal. That might be what's wrong. There's a wire that goes from the ignition switch, to your fuse box, then to the computer that tells it when your vehicle is starting.
Old Apr 29, 2005 | 04:49 PM
VeN0m's Avatar
Also if your lights go REAL dim when cranking...also a possible sign
Old Apr 29, 2005 | 05:00 PM
Maimaxima's Avatar
You said " unless i feed it gas while turning the key " sound like Fuel Pump, check Relay, Fuse, Fuel PSI
Old Apr 30, 2005 | 09:28 PM
5alive's Avatar
Do unto others...
Read the FAQ's
I A C V is Idle Air Control Valve.
T B is Throttle Body.
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
