Pulled a code HELP!!
Old Apr 29, 2005 | 03:45 PM
_maxxedout_'s Avatar
i just did the ghetto hacked airbox mod if that has to do anything with it and remove the bottom resonator. Anyways i got a 0210 which is fuel injector left bank too lean what does this mean help is greatly appreciated i have to get inspection soon!!!
Old Apr 29, 2005 | 03:58 PM
lilonasis's Avatar
all ecu codes are define in the "help my check engine light is on"
0210
Diagnostic Trouble Code 0210 points to a problem with the fuel injection system. When the engine management system is running in closed-loop mode the Engine Control Unit (the computer) makes continual adjustments to maintain the air-fuel ratio near the ideal point. To achieve this it relies on signals from many sensors including the Mass Air Flow Sensor and the Oxygen Sensors.
This malfunction is detected when the ECM finds that it cannot properly control the air/fuel mixture, and the mixture is too lean (too much air). DTC 0210 indicates this problem exists on the left bank (the front bank, cylinders 2, 4, and 6). Possible causes include ...
- Intake air leaks
- Front Oxygen Sensor
- one or more fuel injectors on the front bank
- exhaust gas leaks
- incorrect fuel pressure
- lack of fuel
- Mass Air Flow Sensor
that was copied from here http://forums.maxima.org/showthread.php?threadid=235667
which was copied from here http://forums.maxima.org/showthread.php?threadid=104931
Old Apr 29, 2005 | 04:01 PM
lilonasis's Avatar
Try to clean your fuel injectors first, hopefully they're just clogged.
Mar 12, 2020 12:06 AM
hayne
Oct 5, 2015 11:53 AM
