Auto Transmission
Old May 2, 2005 | 06:41 AM
sleespeed's Avatar
Auto Transmission
I a not real used to auto trannys, so this may be normal.
The car in question is 1997 Maxima, auto of course. It seems like sometimes it just shifts at odd times, and if you are on the throttle lightly, it shifts a little harder. Like while accelerating, it shifts smooth, but if you are like just cruising and it shifts, it kinda shifts hard??
Sorry for my ignorance, I am a 5 speed guy and this is my wifes wip.
Old May 2, 2005 | 07:28 AM
95jr6708's Avatar
Do you notice it all the time? All the maximas i have driven shift the same in my opinion. the hard shift you feel i believe is normal, especially with a cold motor. The shifting also adjusts to the drivers style of driving through the ecu.
Old May 7, 2005 | 09:56 PM
Nissan 6's Avatar
Yea its fine. Same thing happens in my car, i thought it was a problem but i found out that its normal for an older car.
Old May 11, 2005 | 08:49 AM
Jamaha80
mine does the same too. Smooth as silk when you get on it, and a little rough around the edges when cruising. Ive had my max for about a year and it has done it since then. Tried changing fluid, and adding an additive but its about the same.
Old May 11, 2005 | 09:09 AM
njmodi's Avatar
Do I get a tax break?
Its a feature.
Old May 11, 2005 | 09:33 AM
THT's Avatar
THT
Throbbing member
Weird...mine shifts smooth all the time once the car is warmed up. Flush the fluid, drop the pan and clean the magnet.
Old May 11, 2005 | 10:32 AM
brad kay
my car also has similar shifting habbits to yours.. no biggy.
Old May 11, 2005 | 11:30 AM
MaxKlinger's Avatar
Dittos....except for when it's cold, mine is failrly smooth...flushing your fluid anc cleaning the pan is probably your best bet. If you're not slipping, don't worry about it.
Old May 11, 2005 | 11:35 AM
Maximized Jiggs's Avatar
Mine always has a rough 1-2nd shift and I hate it.
Old May 11, 2005 | 01:03 PM
BK1's Avatar
BK1
Hello
Doesn't a firmer shift mean less slipping? If this is the case, then I like the firm shifts.
Old May 11, 2005 | 02:04 PM
i30ds's Avatar
Armed and Dangerous
In the case of autos, firmer is better... at least from a wear point of view...
Old May 11, 2005 | 02:24 PM
nosispower's Avatar
Mine shifts rough 1-2, especially when cold. I don't think it's anything to worry about.
user 11122324
42
Jul 18, 2022 03:35 PM
BobTX10
Oct 7, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
