Brakes pedal feels soft or spongy
Old May 2, 2005 | 09:38 AM
sohailnz's Avatar
I installed pads 2 months ago on my maxima 95 gle. All of a sudden I notice that i need to press the pedal further down in order to engage. It stops fine but the pedal needs to be pressed further. Is this dangerous? What could have gone wrong. Need help as I commute quite a lot!
Old May 2, 2005 | 09:41 AM
renatonetmail
i've heard they are spongy for while when you install them. but everything's been ok according to you for 2 month and all of the sudden this?? I hope someone else can pitch in cuz i have no clue.
Old May 2, 2005 | 09:49 AM
Bobo's Avatar
Is there any brake judder? Which pads were installed - front or rear? Did you have the rotors turned? Did you bleed the brakes and if so properly?
Maybe you need new rotors.
Old May 2, 2005 | 10:11 AM
knight71's Avatar
Check for low brake fluid, if it's low top it up., or it could be a failing master brake cylinder.
MDeezy's Avatar
I'd check fluids, and maybe get a re-bleed. If a couple months later it starts to happen again, there is a leak somewhere.
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
ef9
Sep 10, 2015 10:35 PM
jcvgn
Sep 10, 2015 08:03 PM
