Red/Clear tails question
Old May 3, 2005 | 08:19 PM
Doc's Avatar
Doc
Ordered my red/clears from CM today at that good price of $95 shipped. It should arrive tomorrow and I was wondering whether there is any/much difficulty in installing this on my car. I apologize for sounding leery, but I want to make sure I make the swap correctly and carefully. I'm assuming they will come with some sort of basic instruction on making the swap. Any input you all may have in terms of helpful tricks is welcome. Thanks.
Old May 3, 2005 | 08:26 PM
2 Da Max's Avatar
if anything just check out the how tos, they should be the same
Old May 3, 2005 | 08:47 PM
Doc's Avatar
Doc
I was studying through the FAQ's and 'how to's' but found nothing about replacing the tails with red/clears other than how to make my own. I searched for quite a while, too, but found nothing to help. Thanks for your input, though.
Old May 3, 2005 | 08:49 PM
CKOTuHA's Avatar
There is nothing hard besides pushing out you stock tails out. Sometimes it could be a pain.
Other then that, its 4 screws on each side.
Old May 3, 2005 | 08:51 PM
Doc's Avatar
Doc
Excellent. Thanks. Are the OEM tails sealed with some sort of silicone that helps hold/seal them in place? I once remember someone saying this was the case and made them a bit tough to push out without cracking the housing. Just trying to be cautious here.
Old May 3, 2005 | 08:55 PM
Nismotic's Avatar
Always sunny in philly
Whats going on, Doc? The only hard part about this process is getting your OEM tails off. Just have patience.
Old May 3, 2005 | 08:56 PM
PandaXpress's Avatar
without cracking the housing..is when you bake the tail light to open it up....there is no silicone surrounding the entire headlight onto the car..just it gets dry back there...and it gets a little stuck..take out the screws and push.
Old May 3, 2005 | 08:57 PM
Doc's Avatar
Doc
Gotcha. I'll be patient for sure. BTW, exactly when did you change your name in the org here? Just curious, brother.
Old May 3, 2005 | 08:58 PM
MystA RavE's Avatar
Doc...what are you planning on doing with your stock tail pieces? I'm also going to get the ones from CM but I dont want my other ones lying around. Are you planning on selling them...if yes how much do you expect to get for them?
Old May 3, 2005 | 08:59 PM
Nismotic's Avatar
Ever since Sprint brought the org back to life.
Old May 3, 2005 | 09:02 PM
Doc's Avatar
Doc
Not sure. I'm thinking of maybe selling them if there is an interest for them, but I wouldn't know what to ask at this time.
Old May 3, 2005 | 09:03 PM
Doc's Avatar
Doc
Cool...lol. What was your old name here? Getting old and can't remember, but I do know it was cool.
Old May 3, 2005 | 09:04 PM
Nismotic's Avatar
(cough)chillinmax(cough)
Old May 3, 2005 | 09:08 PM
Doc's Avatar
Doc
That's right! lol...I loved that name. I also love your car. That thing is sweetness. Not overstated, but very classy and well done.
Old May 5, 2005 | 04:25 PM
maxihari77SE96's Avatar
Can you tell me where you got them from?
I like that price...
Thx
Old May 5, 2005 | 04:50 PM
ewuzh's Avatar
Check the group deals forum.
Old May 5, 2005 | 04:58 PM
Luxor99's Avatar
Doc - hope this helps. Just follow the beginning where the instructions for removal are. You may have to tap on the screw heads with a hammer, the lights are in pretty tight. Then just push them out. Also, the black sticky stuff is really tacky. Try not to get it all over the place, it's a pain to get off. Just take your time. I also have the cm ones, fitment is good and you get new weather stripping to seal the lights.
Nismotic - love the car man! one of my favorites on the org!!
http://www.vqpower.com/v2/modules.ph...howpage&pid=34
Old May 5, 2005 | 06:17 PM
Doc's Avatar
Doc
Lux,
Thank you for your assistance on this. I installed them last night and it went very well. Pulling the old ones wasn't as tough as I imagined because I basically grabbed the inner section of the light on the outside (if that makes any sense) and used the leverage of the light against itself to pry it loose. You are right, that black seal is a Bish, though. Stuff is extremely hard to get off of anything. All in all a success and the look is sweet.
Old May 5, 2005 | 06:52 PM
Armani
I too was told that the hard part was getting the tails off. I was inexperienced in taking off the tail lights. I would have done it differently and with much ease now.
As I recall correctly, the directions have you get in your trunk and try using body parts with enough force to yank the tail light out. Although this worked, the second time I did my tails I simply heated the black silicone (or whatever that is) around the edges with my heat gun and the light came out:
1) oh say about 10x faster
2) oh say about 10x smoother
3) oh say....what is "force"?
Old May 5, 2005 | 06:58 PM
Doc's Avatar
Doc
I actually was surprised that the tails came out so easily without any aid from heat or otherwise. Don't get me wrong, they weren't very easy, but I pulled them out without climbing in the trunk and pushing them. I worked the light against itself and a fulcrum and they wiggled out with relative ease.
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
