Where is the IAC Valve?
AHH i cant find the IAC valve. I know it needs to be cleaned. My car has 158k miles on it and i know it hasnt been cleaned. I think im losing power in my car. I only trapped at 89 in the 1/4. I had a 2.1 60ft. My muffler is disconnected and i could be losing power. AH gtg here come the teacvher
The IACV is right behind the throttle body; Follow the air intake from the filter/maf back to the throttle, where the intake manifold curves around. The IACV is back up toward the firewall, and has three wiring harnesses going into it - one is gray (middle), and the other two are pink and purple. Pretty easy to take off and clean, held on by three bolts - the back bolt is kinda tough to get back on...
I just cleaned the IACV. It was fairly easy to remove. I used a 3/8" driver, 12mm deep socket and 10mm deep socket. Its a little tight but you can manuever with a little patience. The key is to remove the small screw holding bracket to get to the right upper screw. After its removed you want to use Throttle Body cleaner to spray everything on the IACV. I also took a rag and sprayed some throttle body cleaner just to get any dirt inside where the IACV is mounted. It was real dirty given that I have 120k miles. After your done just do the reverse and remember to tighten the three mounting screws to about 22 lb-ft.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
