fstb differences
From reading a lot in these forums, it seems a FSTB is a must for performance mod...I'm just wondering is there any real difference between the stillen fstb or the courtesy?
is it just looks or is there a difference? I forget what it was on stillen's site but it was a lot more $....
also this should be pretty easy to install for a first do it yourself mod...right? although i dont have a torque wrench
NO
The Stillen is solid and the Courtesy isn't. The Stillen is more expensive. The effect you will hear is they are pretty much the same. The guy from Courtesy said to buy the 2000-2001 for the 4th gen. then you won't have to hacksaw the piece off the strut tower.
another alternative
Courtesy FSTB
Good Luck.
Originally posted by t2000j
they're all teh same performance wise...
I installed my Cattman FSTB and it's beautiful. A nice solid piece of work, subdued look so it doesn't appear like it's an afterthought, and it fits absolutely perfectly. I've heard stories of these other FSTB products not fitting "quite right" and needing modifications. The Cattman FSTB is very adjustable. Took me less than 20 minutes to install it (not including getting those awfully tight nuts off the strut bolts!). And when cornering at speeds over 30mph, it's a noticeable welcome improvement!
well, after having both on my car, courtest and stillen, i'm very glad in my decision to buy the stillen. how people can say there's no difference, i have no clue. i've gotten much greater response out of the stillen, than i did the courtesy fstb. the courtesy is hollow inside, just as the streetbeat one, as opposed to the stillen which is solid. and where it mounts, if you notice, it's a complete one, and goes all the way around. the courtesy's doesn't. which also doesn't help performance wise, when the mounts on the brace don't make full circle to help. i know that sounds like a minor detail, but hey, when i autocross my car, i've been able to tell a very significant difference between the two. if you just want an fstb to have one, get the courtesy becuz of it's price, if you want a more fashionable one (in my opinion) and better performance, get stillen!
Adam
Adam
I gots the generic procarparts FSTB. It is made of solid aluminum with steel end pieces. Everything fit perfectly on my '95SE. I did have to lower the air conditioner pipe on the left by lowering the bracket. When tightened up, it is a solid piece of work that I am quite happy with. Cornering feels much more controlled and stable. Although I can't say that there are no differences among brands (never having owned any other), I will say that it's hard to imagine another construction being appreciably more solid as to make an appreciable difference in performance--I think others agree with this about their own FSTB and that's why this is being echoed time and again.
Originally posted by LucentAUTO
FSTB doesnt really make the car better. It's mostly for making the engine look better. I suggest you get sway bar instead.
K
FSTB first, then RSB
Originally posted by kit
other than FSTB, i would like to hear something from the people who got RSB. does it really improve cornering a bit? 'coz i've been told suggested to get a RSB when i was considering getting a FSTB.
If you look at everyone's performance mods they've done, chances are very good you'll see "FSTB" in their list. There's a reason for it--they work! I myself was skeptical. After installing mine and driving in normal traffic, I felt only a slight difference. But when I took my Maxima beyond 25mph and leaned into a few curves, it was definitely noticeable to me. Handling felt more controlled.
The RSB will help reduce rear body roll, and will be a slightly less noticeable change than the FSTB (based on what I've heard--I don't have a RSB installed). If you really corner at high speeds a lot, you should get one. Otherwise, you can really get by with just the FSTB. Again, personal preference and willingness to spend more $$.
As for the addco bar, I think it is rather underwhelming physically. Although the Stillen unit is $100 more, from the pics, it seems like that would be the unit to get--looks more solid, and just plain looks better. Stillen unit is adjustable too.
As for body roll, there is still noticeable roll but it is reduced. Next on my list are H&R springs/KYB GR2s.
Adam
Adam
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
