Engine Coolant Temp Sensor: Where is it?
Old May 5, 2005 | 12:44 PM
ardika's Avatar
I want to replace the engine coolant temp. sensor and was told that there are two sensors. One is for the ECU while the other one is for the dash gauge.
Is this true? I thought we only have one sensor near the radiator hose?
Old May 5, 2005 | 12:49 PM
Loe max's Avatar
http://www.autozone.com/servlet/UiBr...3d801f4eba.jsp
Old May 5, 2005 | 02:04 PM
killerVQ30DE's Avatar
Doesn't clearly explain where it is though
Its in the upper radiator hose, normally your snorkel air intake will obscure the view, so remove that and there it is.
Its the sensor on the right in pic
Old May 5, 2005 | 06:46 PM
ardika's Avatar
Wow! Great instructions and an excellent picture! Thank you guys! I always thought that it's near the thermostat housing.
My water temp needle has been jumping up and down in the past three years, I would need to check this sensor right away.
Thanks again!
Old May 5, 2005 | 06:53 PM
Thanks again!
If you Needle jumps round then its the Sensor on the left. The one on the right is the temp sensor for ECU that retards engine if engine out of norm temp ranges
Old May 5, 2005 | 07:02 PM
ardika's Avatar
By saying sensor on the left means that single black-wired sensor probe is the dirtiest in your picture, right?
The one you are saying for ECU is the two-wire-sensor (yellow and black), right?
(don't want to insult you really, but I just want to make sure it's the right one)
Thanks a bunch!
Old May 5, 2005 | 07:15 PM
Thanks a bunch!
Yup
The dirty one with just the single black cable is for the temp gauge.
The one with yellow & black is the ECU one.
I just replaced my ecu one last sunday, the car is much more stable, when accelerating it is very much smoother. my ecu temp sensor cost about $20 so i'd probably replace both.
Old May 8, 2005 | 03:01 PM
ardika's Avatar
Done! Yayyy!! No more needle jumping now. The connections was apparently dirty and very sensitive to vibration, resulting in the temp needle jumping up and down.
I could not take it off, so I just cleaned it really good with hand, and Aerokroil.
Thanks for the picture, I have been dealing with this problem in the past 2 years now, so finally this is the root of it.
Old May 8, 2005 | 03:18 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
my coolant temp sensor may be going bad. is there a way to test it using a multimeter to see if its bad?
Old May 8, 2005 | 03:20 PM
No worries
Old May 8, 2005 | 05:43 PM
Yeah you can meausre the voltage, its in the stickies.. or just replace for $20
Old May 8, 2005 | 06:17 PM
Vlasic's Avatar
i didnt see anything about the CTS voltage in the how tos, or the FAQs. does anyone know what the proper voltage is for the cts?
Old May 8, 2005 | 08:23 PM
Doh! I just checked and can't see them either, I'll type them in from my manual if I get a second tonight.
Do you want the temp gauge sensor or the ECTS (ecu one)?
Old May 8, 2005 | 09:01 PM
Vlasic's Avatar
the big one, the ECTS.
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
