New trans symptoms :(
Old May 12, 2005 | 03:10 PM
nismos14's Avatar
§è~® f®ÈÄk
If I'm going roughly 10-15mph and put it in first (don't worry I never downshift like that, but it's just something that caught my attention) I get a very strange winding noise. Also if I do the same to go into 2nd gear it does it as well, usually around 20mph. My other symptoms are that when the car is not in gear and my foot is completely off the clutch, I get some what of the same noise, except not as loud. When I get my foot all the way down on the clutch the noise goes away, until I begin to release and about 2 - 3 inches up from the floor I get the noise again.
It's like the sound of a small turbine turning on... sort of hard to explain.
Any input is greatly appreciated!
Old May 14, 2005 | 09:55 PM
madden's Avatar
Same Exact problem!
I am experiencing the exact same behavior word for word!
wondering if you have found out what it is?
I suspect that it is the drive train bearing that needs to be replaced, so i am thinking of rebuilding my transmission. I think this because I actually crawled under the car while in neutral and listened to the transmission and there it doesn’t sound a fan anymore there it is a more mechanical sound, kinda like the one old ball bearings make
What I am going to try for now is go to the dealer and see what they say.
Old May 14, 2005 | 11:36 PM
afroken's Avatar
mine did the EXACT same thing until 2 weeks ago when the trans seal busted along with all my bearing and synchros...max is stuck in the driveway until tranny rebuild. try www.car-parts.com if you want to go with a used tranny.
Old May 15, 2005 | 12:48 PM
oVeRdOsE's Avatar
I got my max for 3 weeks now. I HAVE THE SAME PROBLEM. But dont worry, 95 and 96 max has all the same problem. (oil leak, bearing problem, strange sound), any way, i I went to tranny garage, and the guy knows the max tranny by heart, he said thats not good but you can ride ne way. BUT look if there;s enough oil in the trans!!!!!!!!! !!!!! REALLy important! because the 95 and 96 seal always cracks.
But dont take chance, go for a rebuilt, thats what im plannig to do, but i need money (around 800 and 1300$)
Old May 15, 2005 | 06:21 PM
nismos14's Avatar
§è~® f®ÈÄk
I think it is my throw-out bearing, however i have yet to fully determine what it is. I don't think its diff bearings because the trans was taken out a year ago and it looked good inside.
Old May 15, 2005 | 07:04 PM
Scruit's Avatar
U wanna try me young boy?
I had a similar issue a couple years back. I was due for a clutch job anyways so I did the clutch and also replaced the release/throwout bearing. While the trans was aout I also checked the amount of play in the input shaft and found it was VERY loose - turns out my issue was a damaged input bearing. Did the rebuild myself, only cost $30 for the bearing and a few more bucks for the permatex and trans oil.
Old May 16, 2005 | 04:36 AM
nismos14's Avatar
§è~® f®ÈÄk
I wonder how much my local mechanic is going to charge, well thanks for all of the input scruit and others.....
Old May 16, 2005 | 07:33 PM
oVeRdOsE's Avatar
Do you want rebuilt it yourself???
There is the link, http://www.motorvate.ca/mvp.php/805
and it worth, thats what im doing now, BUT it takes more time than im tinking
Old May 16, 2005 | 08:02 PM
I30tMikeD's Avatar
It is not the throw out bearing, I kinda hoped it was too but after replacing it while putting in a new clutch the noise remained. Many, many Nissan's to this and I am sure other cars as well. My friends 350z does it. It is most likely the input shaft bearing. I know of some that have had the bearing end up failing, but I also know guys like myself that have had the noise for a long, long time and nothing happen.
Old May 17, 2005 | 06:45 PM
nismos14's Avatar
§è~® f®ÈÄk
Everyone who has heard it and i've explained it to has said throw out bearing. But, I'm thinking it might not be so. What other symptoms would I have with a bad input shaft bearing? How expensive would it be to replace?
Thanks in advance for the help!
Old May 17, 2005 | 07:41 PM
I30tMikeD's Avatar
Dude trust me. I know exaclty the noise your car is making. It is not the throw out bearing. That is an easy assumption to make and understandable why a person who may not be very familiar with maxima/nissans would think that.
Input shaft bearing is not something simple....well it is, but it is not easy to get to. Gotta drop the trans
Old May 17, 2005 | 08:11 PM
nismos14's Avatar
§è~® f®ÈÄk
So if someone is going to do it for me, should I go ahead and have them put in a clutch at the same time? I have a craptastic luk clutch in it right now. If the trans is going to have to be dropped anyways, might as well replace the clutch right?
Also, anyone know how much the input shaft bearing replacement should cost? (roughly)
Old May 18, 2005 | 08:59 AM
nismos14's Avatar
§è~® f®ÈÄk
bump it up, price? replace clutch at the same time?
Old May 18, 2005 | 01:36 PM
i30ds's Avatar
Armed and Dangerous
Definately either an input shaft bearing or main shaft bearing. My friends 96 is doing this as well. We are gonna drop his tranny this summer and replace both input bearings and main bearings.
This seems to be a common problem along with the notorious differential side bearings. I think it is safe to say that the manual tranny is weak spot on this car.
Read this:
http://forums.maxima.org/showthread....g+clutch+noise
Old May 18, 2005 | 04:01 PM
nismos14's Avatar
§è~® f®ÈÄk
So the only way to really know which one it is, is to have the trans dropped, I assume. Anyone now where I can get these parts and how much they cost?
Old May 18, 2005 | 04:09 PM
i30ds's Avatar
Armed and Dangerous
www.everythingnissan.com 1-480-941-0055 (infiniti of scottsdale)
All nissan parts available wholesale (50% off dealer list)
Old May 18, 2005 | 04:18 PM
nismos14's Avatar
§è~® f®ÈÄk
hmm the only bearing i see listed there is a release bearing, which i'm assuming is the same as the throw-out bearing, thanks for the link and number
anyone else know of any places?
Old May 19, 2005 | 05:40 PM
madnut's Avatar
This no new posts thing is lame !
I was woundering if anyone knows if the Chilton Book has any details for the transmission, like where the input bearing is and some diagrams from inside the trany.
Old May 19, 2005 | 09:12 PM
madnut's Avatar
Where is this input bearing located? does anyboday have a picture a diagarm or iscription?
Old May 20, 2005 | 06:56 AM
nismos14's Avatar
§è~® f®ÈÄk
Its on the input shaft lol i got a quote for clutch install plus full bearing re-build done at goodyear, I'll supply the clutch, and they will get the bearing kit, I'm looking at $1380 + clutch ~$200 for fifth gen clutch.....$1580 any input on that price? Is it a good price?
They also have a finance option where I only have to pay ~$115 a month on it for 12 months
Old May 20, 2005 | 10:23 AM
madnut's Avatar
I asked everythingnissan to see how much is a new VLSD transmission would be, they qouted $1700 + shippings
And just putting a new tranny in is a pritty simple job
Old May 20, 2005 | 10:26 AM
madnut's Avatar
The problem with dealer rebuilds is that they freqently mess up the pre-load and the rebuild falls apart in like 20,000 miles, conviently it is right after the warr expires
Old May 20, 2005 | 11:23 AM
nismos14's Avatar
§è~® f®ÈÄk
lsd tranny requires new axles if you don't already have a vlsd. Goodyear is going to re-build it, not the dealer.
Old May 20, 2005 | 12:14 PM
i30ds's Avatar
Armed and Dangerous
For that price you could almost get a new vlsd tranny. I got mine from everythingnissan for $1650 plus $50 shipping. Add another $150 for rebulit vlsd axles for a total $1850. So, if you take a solid weekend to do the install yourself, you get a brand new tranny, vlsd, and new axles an extra $450 compared to the $1400 rebuild.
No finance option of course, and it is more money and work, but I think it would be worth it...
You could also attempt to replace all the bearings yourself... your car would be down forever though...
Old May 20, 2005 | 12:16 PM
nismos14's Avatar
§è~® f®ÈÄk
1) I don't have that much time to work on my car
2) I don't have any place to do the work
3) I don't have the cash to do that all at once
Old May 20, 2005 | 12:24 PM
i30ds's Avatar
Armed and Dangerous
Looks like the payment plan is your best option.
Old May 20, 2005 | 02:44 PM
nismos14's Avatar
§è~® f®ÈÄk
Yup sadly, oh how I would have loved to have a VLSD
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
zmcneely13
Sep 26, 2015 02:26 PM
