rack and pinion problem?
Old May 12, 2005 | 09:10 PM
lil_Jay22's Avatar
I wanted to know if any of you might know how I could check which side is messed up or if it even is the rack and pinion. recently when I punch the gas my car would pull to the left. I noticed when I punch the gas and let it go it feels like my car hidroplanes for a bit moving from side to side. but just in the last two days when I punch the gas the car pulls to the right. the car was just recently alligned and when left in neutral it goes straight. as well as when braking it goes straight. the problem is the acceleration. since it changed from pulling from the left to the right I wonder if both are going bad.
Old May 12, 2005 | 10:59 PM
NmexMAX's Avatar
dot dot dot ...
Torque steer anyone .... Also it may be your tie rods(inner & outer) I cahnged mine and lost the floaty feeling. .
Old May 12, 2005 | 11:32 PM
lil_Jay22's Avatar
I forgot to mention that right before this started I had to disasemble the passanger side knuckle to get a new bearing pressed in becuase it had gone bad so I'm not sure if I might have damanged anything.
along with this problem when i turn and hit bumps or go of a driveway I hear metal cluncking which a friend of mine said it might be the springs that are not siting right on the sturt assembly but dont know if all this might be related.
Old May 13, 2005 | 12:14 AM
iLuvUrmom's Avatar
Almost definately a strut problem. Probably a weak spring on one side of you car, the right side?, the one the engine makes it pull too. Is that the side it clunks on when you hit big bumps? Steering has nothing to do with acceleration, cause nothing is involved except the transmission and the wheels, besides the engine. Suspension causes the drifty feeling, you're still in control, but when you hit the gas it feels like you are floating. Cause your wheels are connected to the struts which control everything you feel basically, so if one is bad, that wheel goes one way only and the other wheel follows. Only slightly.
That isn't detected in re-alignment usually, they won't tell you what you don't pay for, so take it to a mechanic, and ask him if your struts are bad or leaking oil. Leaking struts will squeak, if you push on each side of your car, a bad spring will be noticable, if it's really bad.
Old May 13, 2005 | 12:29 AM
NmexMAX's Avatar
dot dot dot ...
You my friend have never experienced torque steer ...
Old May 13, 2005 | 03:28 AM
Xugg's Avatar
clunking while turning? possible cv boot problem aswell??
Old May 13, 2005 | 08:58 AM
lil_Jay22's Avatar
the fornt struts are ok the back ones are the ones leaking which I will repalce shortly but the cluncking is heard on both sides left and right of the front.
Old May 13, 2005 | 09:00 AM
lil_Jay22's Avatar
dont know what that is
Old May 13, 2005 | 09:01 AM
lil_Jay22's Avatar
cv boots are fine I've checked them. no cracks or rips
Old May 13, 2005 | 09:03 AM
NmexMAX's Avatar
dot dot dot ...
Me neither
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
fastcarny
Oct 12, 2015 07:06 AM
06maxima55
Sep 28, 2015 04:29 PM
