help with a damn rattling
Old May 18, 2005 | 12:48 AM
Nissan2k5's Avatar
alright i noticed alot of rattling that i can hear from inside the car. the rattling happens when i am driving expecially when i hit bumps. i was just wonderin if anyone could give even an idea of what this could be. i was thinking maybe some bolts r loose? im not sure if anyone could help id appreciate it thanks
Old May 18, 2005 | 06:42 AM
NmexMAX's Avatar
dot dot dot ...
This subject has been covered in the past, and most remedies, depending on the location of the rattle could be fixed by adding cotton in between rattling surfaces and pushing them in further with a credit card or ID so that it doesn't look so ugly .. worked for my 10 yr old, 228k car .
Old May 18, 2005 | 07:45 AM
blaze0ne
check this thread out for some solutions:
http://forums.maxima.org/showthread.php?t=370908
Also there is a Nissan TSB #98-110 Interior - Squeak and Rattle Repair Supplies
I couldnt find a free site that actually displays the TSB but you should be able to find it somewhere.
The many maxima TSBs can be found here: http://forums.maxima.org/showpost.ph...2&postcount=17
Old May 18, 2005 | 09:48 AM
NmexMAX's Avatar
dot dot dot ...
I think on our cars since they're already or close to 10 years old, the TSB may not be the best option, do what i said and see how you like it .. rattles will be there if we like it or not, especailly on an older car. And one of the threads you pulled up was mostly geared toward 5th genners, hence being newer.
Nissan2k5's Avatar
thanks guys but if i cant locate the rattles it may be hard but ill try thanks later
user 11122324
42
Jul 18, 2022 03:35 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
