Tires
Old May 18, 2005 | 10:02 PM
88FordFestiva's Avatar
Tires
Say I want to put 19 inchers on an otherwise stock 98 GLE. What should I look for in the other two numbers that the tires have? Still 205/65? What look will I get from different numbers?
Old May 18, 2005 | 10:24 PM
ThisMaxIsTight's Avatar
lol ... dude you really should read up on rims and tires ... 205 is the width of the tire and 65 refers to the height .. for a 19 inch rim, your going to have a very low profile tire .. the idea of the ideal rim and tire package is to keep the OVERALL height(which means the height of the rims and tire together) as close to stock as possible, this way the gears and speedometer still function the same as they would as stock .. bigger rim, smaller tire -- smaller rim, bigger tire ... check out www.tirerack.com 205/65 is not even close to what you would match a 19 inch rim with .. good luck
Old May 18, 2005 | 10:36 PM
NmexMAX's Avatar
dot dot dot ...
235-35 19 will be a good fit ... Or get over your laziness and use these various calculators located in the **TIRE** and wheel forum ...
http://www.forums.maxima.org/showthread.php?t=243784
Old May 19, 2005 | 07:04 AM
Bobo's Avatar
The problem is you will still have the 4x4 look unless you lower the car.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
