Weird problem
Old May 20, 2005 | 12:51 AM
newport2k's Avatar
Weird problem
Ok here is my living hell... turn my key and i get no lights on the dash,no needle movement from gas,tach,temp even mileage. Also my windows will not work( will workk after the car has been running for a bit) Lights on the dash also start working after a bit of running but very dim. Rear defog switch does not work. also heat/ac blows but does not light up and a/c does not kick on.But the car will run...
Old May 20, 2005 | 02:36 AM
smokeyone's Avatar
Well no lights seems like battery to me. Does it have any problems starting? long cranking and such? Check ur fuses too. Good luck!
Old May 20, 2005 | 03:13 AM
AllMaxxedOut's Avatar
Sounds like drained battery. Don't think it's the alternator but not sure as nothing posted about hard starting. To start, use a multimeter to check your fuses like smokey said to see if they are on their way out. If it's not the fuses, maybe use a battery charger connected to the battery to see if the lights come on right away. Post what happens.
Old May 20, 2005 | 04:31 AM
Chickan's Avatar
Yeah sounds like battery or alt or both.
Old May 20, 2005 | 06:51 AM
zazon's Avatar
ya man get a 10 dollar multimeter and download a factory service manual from my site, http://zazon.us/maxima
Old May 20, 2005 | 09:47 AM
newport2k's Avatar
ok problem is alternator was replace by nissan a yr ago and the battery is brand new.the car will start right up with no problems
Old May 20, 2005 | 10:49 AM
maxgtr2000's Avatar
KH3 by popular demand
Ignition switch probably going out, there is a wire I think its blue and red that is supposed to have potential for things like the a/c, if not powered these accessories will not work, check with a remote start wiring diagram to make sure; but if it is not getting that contact that is made with the ignition switch they won't come on.
Old May 20, 2005 | 09:53 PM
newport2k's Avatar
alright thanks. UPDATE I wass tinkering around and pulled a few fuses now here is the kicker i pull out fuse #13 with the engine running then the windows will work and the rpm gauge and everything else starts to come on then i put the fuse back and everything goes out and there is a huge load on the engine as you can hear the drop in rpm.
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
