OD button
Old May 21, 2005 | 11:18 PM
maxima1985's Avatar
OD button
I was at the track last night and my OD wasn't working so it messed up my times...did anyone else have this problem, and if so, how do you fix it?
Old May 21, 2005 | 11:22 PM
ethnic6's Avatar
actually, I do have a follow up question, exactly does an Overdrive do? the only thing I know is that it gives u more torque, but can anyone else give me a better description
Old May 22, 2005 | 03:27 AM
nosispower's Avatar
It doesn't give you more torque, it just prevents the car from shifting into 4th gear. Nothing else.
I actually have the same problem though. I can't turn my O/D off.
Old May 22, 2005 | 04:01 AM
filter27e's Avatar
Turning your Overdrive ON allows you to shift into 4th.
Old May 22, 2005 | 05:18 AM
MaxxedOut624's Avatar
Yeah I thought OD allows you to go into 4th gear.
Old May 22, 2005 | 06:20 AM
nosispower's Avatar
Yeah, that's what I meant. Pressing the O/D OFF button locks out 4th gear.
Old May 22, 2005 | 07:07 AM
drivinmax
od is cool i'll get up to 130 and then turn the od off and it makes you go faster
you can leave it off for long bcuz you motor will like blow up
Old May 22, 2005 | 07:17 AM
njmaxseltd's Avatar
Overdrive should have nothing to do with your times at the track.
Your tranny will never see 4th gear in the 1/4 mile.
Old May 22, 2005 | 11:53 AM
maximaintheface's Avatar
ur wire prolly came loose or your switch is broken. take ur center console out and see if the wires are still connected . if they are ir might just be the button. i have mine set up to a regualr switch right now.
Old May 22, 2005 | 12:09 PM
5alive's Avatar
Do unto others...
You Must B Kidding
You DON'T take your center console out!
If you take the shifter trim off(holds cigarette lighter socket), you can
access the wires from there. If you need to get at the connection, unscrew
the two screws in the front of shift handle. Then, pull handle up and off.
You will then see the soldered connections.
Note: CAREFUL WITH THE SHIFTER BUTTON SPRING
Old May 22, 2005 | 06:35 PM
maxima1985's Avatar
it does have something to do with it...with it off, my 3rd gear goes by a lot faster than with it on, and it did slow down my car. and my last run at the track was a 15.6, now I'm back to running 16's??
Old May 23, 2005 | 06:23 AM
scrhale's Avatar
Dude ... the only reason to use O/D-Off is when you are sitting in traffic. You don't want your auto to shift into 4th doing 25 MPH because it is uncomfortable when you reaccelerate and the car downshifts into 3rd.
Now for my own question. When I turn OD off doing like 75-80 it downshifts to 3rd (OBVIOUSLY). But then when I turn it back on to go back to 4th, first the RPMs jump and extra 200-500 and then it shifts to 4th. What's up with that?
Old May 23, 2005 | 06:36 AM
mzmtg's Avatar
Minister of Silly Walks
No it doesnt. it ONLY locks out 4th gear.
Old May 23, 2005 | 07:10 AM
95jr6708's Avatar
The jumping is normal.
Old May 23, 2005 | 10:56 AM
maxima1985's Avatar
then what would cause my car do be 1/2 sec slower on the track?
Old May 23, 2005 | 11:16 AM
tavarish's Avatar
fwd gone rwd cr00
wow.
Old May 23, 2005 | 11:32 AM
NmexMAX's Avatar
dot dot dot ...
Creepy isn't it ........ ^^
tarun900
19
Dec 20, 2021 06:57 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max139617
Sep 29, 2015 06:44 PM
EdRomo86
Sep 12, 2015 07:49 PM
