Where else can I tap into to get 12V for accessories besides the cigarette lighter?
I have about 5 things I need to get 12V to but I?m afraid to run it all through the cigarette lighter wire. I need whatever wire I tap into to be one that only has power while the car is on. Can anyone tell me which wire I might be able to use?
power seat wire, under the seat. the wire for your head unit, pretty much all ive taped into so far. what are you hookin up, if they are small things like LED's which dont require much power u may be fine.
I'm hooking up a radar detector, a radar gun I like to play with every so often, another old POS radar detector I'm just going to put under the seat because when it starts up it says "welcome buckle your seat belt" and everyone that gets in and hears it thinks its coming from the car and think its the coolest thing, some LEDs, and a AC/DC power converter.
just to let you know, usually if you install 2 radar detectors, a lot of times they conflict with each other. and i wouldn't suggest making the radar detector permanent when it plugs into the cigarette lighter just in case you want to take your radar out of your car and put it in your friend's car since he's driving and not you. i used to run a lot of strobes and stuff and i just run it straight from the battery to a switch to turn stuff on and off. obviously the switch would be fitted into a spot where it looks clean and looks like its a factory switch
Everything but possibly the AC/DC power converter should be fine, radar detectors don't draw hardly any power. I ran an extra power cable myself from the battery and actually mounted a second cig lighter underneath my seat, strapped it to a metal support bar for the seat, is out of the way and looks pretty clean.
If you want to make it so it turns on/off with the car, buy a 12V DC relay ($3-5) and run a loop off of your cig lighter, this will turn that power supply on with the car.
I would run wires from the battery but last time I ran wires from the engine compartment into the inside of the car I had to drill a whole and take the carpet up and a bunch of other sh*t and I was trying to get around doing that again. So if someone could tell me a place to run wires from under the hood into the inside of the car that would be great.
Originally Posted by bigx323
be careful with that radar gun, i hear many of those bike cops have problems having kids after excessive use of those guns.
In my old car i tapped into the cigarrette lighter and ran wires up under the dash, up the a pillar, across the headliner, and mounted a second cigarrette lighter behind the rearview mirror. I just used electrical tape, and it actually looked pretty clean, becasue the socket was strapped to the post for the mirror. the reason i did this was to avoid the cord hanging down from the detector to the socket. It also allows me to have the detector right below the rearview, and since im always checking the rearview for po and retards about to rearend me, i still see it going off even if the music is up too loud to hear it....
AaronL
Nov 15, 2020 11:52 AM
