Sub-Frame connectors or RSB ?
Old May 25, 2005 | 02:59 PM
MaximA StyLeZ's Avatar
What is the better suspension mod ? I've heard greeat things about the sub-frame connectors, yet same thing about the rsb. If i had enough money i would buy both, but can only choose one right now. Any 1 just have sub-frame connectors on dropped max ? Does any1 have both on dropped max ? My only suspension mod is a drop (eibach/illimunas).
Old May 25, 2005 | 03:08 PM
willis's Avatar
My heroine
I vote sfc's if you can get them. I don't have a rsb to compare to though, so take that as you will
Old May 25, 2005 | 03:34 PM
MaximaSE96's Avatar
Maxima Owner
SFCs...they will smoothen out ur eibach ride..celarence should be fine...i am sure warpspeed figured these would be going on to lowered max's
Old May 25, 2005 | 03:42 PM
they're not ready to order tho rite ?
Old May 25, 2005 | 05:04 PM
Gates's Avatar
Can anyone who has the old subframe connectors clarify this? I have heard that SFCs will lower your ground clearance. I already scrape with my existing setup and if the SFCs are even lower than I won't buy them. But if they don't affect clearance I'd love to stiffen up my car a little.
Old May 25, 2005 | 05:06 PM
Gates's Avatar
They are not available as of yet. So, if you want something for now go ahead and get the RSB and you can save up for the SFCs. I have the RSB and I like it. I can notice the difference in the handling.
Old May 25, 2005 | 05:08 PM
LudeAEM's Avatar
I am in the same boat as you maxima stylze's.... but i am betting most people on here will say SFC. SFC will improve chassis ridgeness, smoothen the ride, and remove possible creaks and what not. THe rear sway i heard can harshen the ride if your car is already lowered. Not to mention the SFC is only like 20-30 bucks more.
Old May 25, 2005 | 05:10 PM
1FSTMAX's Avatar
sfc's will lower your ground clearance.
Old May 25, 2005 | 09:51 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
I just put on my rear sway bar.... It makes the biggest difference in the world...I can't believe I ever drove this car without it... It really is awesome!!
The ride is alot smoother, and body roll is almost completely eliminated, and it feels alot tighter at high speeds... SFC's are next for me!
Old May 26, 2005 | 03:59 AM
willis's Avatar
My heroine
they hang down below stock side skirts about an inch, maybe an inch and a half. I'm dropped on sprints, and rarely scrape, so it all depends how you drive. you have to be careful on some speedbumps / driveways, but in general it's not too bad. well worth it.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
AaronL
Sep 23, 2015 03:34 PM
