can someone point me to a 300zx brakes how-to?
Old May 28, 2005 | 12:17 PM
mb1's Avatar
mb1
i couldnt find it in the stickies.
Old May 28, 2005 | 02:30 PM
MAXRB8's Avatar
http://www.mattblehm.com/
http://importnut.net/300zxbrakeswap.htm
http://www.zilvia.net/installs/zbrakes/300zx.asp
Here's some useful forum info:
http://forums.maxima.org/showthread....3&page=1&pp=30
http://forums.maxima.org/showthread.php?t=402326
Good luck, I'm going 13" cobra, just waiting for the rotors, got the calipers, pads, got the SS brake lines from Matt Blem, and the brackets from Jeff92se.
Old May 29, 2005 | 08:51 AM
Nealoc187's Avatar
SLOW
You can get 13" cobra rotors from any auto parts store. Unless you are planning on getting some special ones like slotted or something.
Old May 29, 2005 | 09:05 AM
Maximus_95's Avatar
on the third link there, it shows that the brakes are clearing 16's, the 240sx se wheels or is it because he is using the 26mm caliper?
brooklynK3Y
was looking, but maybe i overlooked.. what items do i need to go about doing this swap ?
Old May 29, 2005 | 11:59 AM
mb1's Avatar
mb1
I think Im gonna go with the 300zx rotors since I already have them. I am mostly conserned with whether I absolutely need the SS lines, and if so, which ones to get. I am on a very tight budget, and dont want to throw extra money around.
Old May 29, 2005 | 01:54 PM
sterlingmaxima's Avatar
yea I am curious to if this setup would fit under the 240 rims
Old May 29, 2005 | 02:16 PM
Nealoc187's Avatar
SLOW
I don't know how many times it's been said, but I know I've said it in every single thread I've posted about 300zx brakes in, which is alot of threads. You MUST MUST MUST MUST use conversion lines. Stock lines are NOT the right style to fit into the calipers and you run the risk of destroying the threads hole on the caliper like I did because I took someone's advice that said you can use stock lines.
Old May 29, 2005 | 02:47 PM
i am still wondering about those rims fitting
Old May 29, 2005 | 03:04 PM
Maximus_95's Avatar
im thinking it may fit if you get the 26mm calipers which i dont think anyone here on the org has the 26mm, we all have 30mm.
Old May 29, 2005 | 04:06 PM
mb1's Avatar
mb1
ok good, finally a solid answer. is matt the only person i can obtain the conversion lines from?
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
