Another Y-pipe Thread(exhaust wrap)
Old May 28, 2005 | 09:46 PM
MaxGordon7's Avatar
Does not wrapping your after market y-pipe(budget) with exhaust wrap do anything to the engine? Ive heard that SS gets much hotter and was wondering if that could damage the engine or other parts/seals.
Old May 28, 2005 | 10:17 PM
Nismotic's Avatar
Always sunny in philly
adding exhaust wrap to your ypipe will wear it down quicker.
Old May 29, 2005 | 12:00 AM
Maximeltman's Avatar
i wrapped just the flex to make it more quiet. and it is more quiet.
Old May 29, 2005 | 07:05 AM
mansurxk's Avatar
you could wrap the flex in aluminum foil and use hose clamps to quiet it down also.
but the exhaust wrap will wear the pipe down.
Old May 29, 2005 | 09:39 AM
dennisadhs's Avatar
Are you serious you can wrap it in aluminum foil??????!!!!!! You gotta be joking right?
Old May 29, 2005 | 09:40 AM
MaxGordon7's Avatar
i wrapped the flex, was thinking of doing the rest but i guess not....
Old May 29, 2005 | 11:25 AM
so i should rewrap the flex section without the wrap? how does exhaust wrap wear it down?
Old May 29, 2005 | 11:50 AM
Bobo's Avatar
I was told by two local racing shops not to use exhaust wrap. It retains moisture, dirt and salt which can result in corrosion to the y-pipe. Exhaust wrap was designed for racing applications and that is all that it should be used for.
Old May 29, 2005 | 12:08 PM
maximavqpower97's Avatar
leave it stock.
Old May 29, 2005 | 01:15 PM
takin it off...
Old May 29, 2005 | 02:32 PM
deezo's Avatar
Yup, don't do it. The pipe should be able to release the heat anyway it can. Heat wrap would be best on intake piping which would keep the air a bit cooler.
Old May 29, 2005 | 04:46 PM
mansurxk's Avatar
is it that surprising? its been done...made sense to me, it aluminum radiates heat pretty well
http://forums.maxima.org/showthread....ight=foil+pipe
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Socalstillen
Sep 26, 2015 12:01 PM
