need help!!!!! PO1320/0210
Old May 29, 2005 | 05:37 AM
drivinmax
Ignition Signal Circuit:
can anyone help me with this on a possible fix.
0201
Diagnostic Trouble Code 0201 indicates a problem with the ignition coil and power transistor. The ignition signal from the Engine Control Module is sent to and amplified by the power transistor. The power transistor turns on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil secondary circuit.
The malfunction is detected when the ignition signal in the primary circuit is not entered during engine cranking or running.
The items to check include
- Harness or connectors (the ignition primary circuit is open or shorted.)
- Power transistor unit built into ignition coil
- Condenser
- Crankshaft Position Sensor (REF)
- Crankshaft Position Sensor (REF) circuit
A misfire on any individual cylinder should set a code, and a problem with the CPS should also set a code.
I would have expected to see DTC 0201 along with one of the following DTCs.
0407 - Crankshaft Position Sensor (REF)
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
You didn't get one of these "companion" DTCs, and that is puzzling. Maybe one of them will show up in the next few days.
Old May 29, 2005 | 12:11 PM
maximavqpower97's Avatar
probably its just your coils.dont think to far of it those codes can often mean just one thing,if your car vibrates its your coils 100% ,remember maximas dont ever after vibrate so just clean them up and reset ECU.
Old May 29, 2005 | 12:24 PM
drivinmax
ya it vibrates like hell how do you clean them?
Old May 29, 2005 | 09:31 PM
thedge7's Avatar
http://forums.maxima.org/showthread.php?t=389309&page=4
