5 speed swap
Old May 29, 2005 | 08:45 AM
KOALA97SE's Avatar
5 speed swap
Is the ECU and the corresponding harness required for the 5 speed swap?
Old May 29, 2005 | 08:46 AM
juani's Avatar
Rockin' VK56!!
ECU is not required but if you use auto ecu then it will throw CEL code.
Old May 29, 2005 | 12:22 PM
i30ds's Avatar
Armed and Dangerous
Try 20 cel codes... you would sit there forever counting the blinks...
Old May 29, 2005 | 12:35 PM
NmexMAX's Avatar
dot dot dot ...
But it's still not REQUIRED ... haha Maxima in a tuxedo .. nice
Old May 29, 2005 | 01:42 PM
mansurxk's Avatar
Khoa,
the harnesses will be teh same, like the others said, its NOT a must, but you'd rather not have CEL's, all the missing components will give CEL's. if you choose to run an auto ECU in a manual, thers a short delay when your slowing down and you shift to neutral. the car will hang at 1000 RPM and then will drop after a split second or so.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
