Ground locations
Old Jun 1, 2005 | 11:20 AM
JetBlackMax83's Avatar
Ground locations
I have a weird problem my brake light and battery light come on and off Sporadically idk but my suspicions are ground contacts loose or dirty wonder if any one knew all the major grounds in the engine bay for 98 maxima thanks in advance
Old Jun 1, 2005 | 11:22 AM
Big_Ham's Avatar
MaximaFreak
Brake light (ebrake light) on means you're low on brake fluid.
djfrestyl's Avatar
Suspension Yoda
dude, punctuation is your friend.
Old Jun 1, 2005 | 11:59 AM
Nope the brake light and battery light come on and off at the same exact time
Old Jun 1, 2005 | 12:04 PM
Big_Ham's Avatar
MaximaFreak
Did you even bother to CHECK your brake fluid or are you just flat out denying that could be the problem?
Old Jun 1, 2005 | 02:20 PM
i checked my brake fluid has nothing to do with the problem
Old Jun 1, 2005 | 02:31 PM
CleanMAX98's Avatar
i have the same prob but mine stays on all the time, its been on for three months now, its supposed to be the alt but every shop i go to says its in working order
Old Jun 1, 2005 | 02:40 PM
njmodi's Avatar
Do I get a tax break?
Its your alternator.
Old Jun 1, 2005 | 02:41 PM
njmodi's Avatar
If only the brake light was on, then yes, the fluid might be low. With both the brake and battery lights being lit, that points to the alternator giving it up.
Old Jun 1, 2005 | 02:42 PM
njmodi's Avatar
1. Did you check your brake fluid?
2. It could also just be a bad parking brake switch - that is not turning off to indicate that the parking brake is released.
Old Jun 1, 2005 | 05:55 PM
RA030726's Avatar
I'm nutty for Nissans
grounding:
alternator to chassis (behind pass headlight)
battery to chassis to block
injectors to intake manifold
tranny to chassis (low on the drivers side strut tower)
harness to chassis (behind pass headlight)
harness to fender (behind driver headlight)
any i missed?
or ground strap on the exhaust, and some in the trunk and a whole bunch inside the car.
Old Jun 1, 2005 | 06:32 PM
i30ds's Avatar
Armed and Dangerous
Thats it... but there is a bunch on the interior and the trunk as well...
Old Jun 1, 2005 | 08:07 PM
JSutter thanks I will check them out this weekend. I did have my altinator swapped out like 10k ago. Im just trying to remember if this was happening before that, from what i remember it wasnt. Do you think they could have put the wrong alt in there?
Old Jun 1, 2005 | 08:12 PM
njmodi's Avatar
Where did you get the swap done? You might have a bad alternator (i.e. bad voltage regulator or diode or something). I would put my money on a bad alternator.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
