Antenna Replacement - Quick Question
Old Jun 2, 2005 | 11:26 AM
sparkyssb's Avatar
Hey folks. I just changed my antenna because the power one looks kinda ugly when it is up but my question is where does the antenna wire run in the car to the head unit? In my trunk, it seems to disappear into oblivion.
Thank you!
Old Jun 2, 2005 | 11:28 AM
kormax97
I believe it goes (from the trunk side wall) up the pillar into the ceiling, back down the pillar, behind the dash, than to your head unit. well that was how it was on my VW... but it might go (from the trunk side wall) to the rear deck, under the rear seats, through the door sills, in to the dash, to your head unit... but yea.. it wouldn't be on your trunk lid or anything...
Old Jun 2, 2005 | 10:37 PM
sparkyssb's Avatar
thanks kormax. However, before I have to dig too far, the replacement antenna I have does not come with a cord long enough to go through the roof and down the pillars, ect. So...(if anybody knows)..does that mean that the factory one has an extension that I can tap into or do I have to cut the factory cord and my current antenna cord and patch them together? Any suggestions would be appreciated to make the job as painless as possible.
Old Jun 3, 2005 | 12:27 PM
sparkyssb's Avatar
bump
Old Jun 3, 2005 | 12:34 PM
njmodi's Avatar
Do I get a tax break?
The factory antenna wiring runs to the from the HU to the antenna motor assembly in near the scissor jack in your trunk... if you mounted your new antenna there, you might be able to patch into it there.
Old Jun 3, 2005 | 01:06 PM
Wetballoon's Avatar
I don't know about extensions, but the cable does run up the rear right pillar past teh rear window and through the ceiling, I'm not sure how it is routed other than that, but it is. You should check in the qtr panel and see how the ant connects to the cable there.
Old Jun 3, 2005 | 02:28 PM
Northern Maxima's Avatar
What type of antenna did you get and what does it look like? I've always thought one of those shark fin antennas on the roof would be cool.
Old Jun 4, 2005 | 08:24 AM
sparkyssb's Avatar
thanks folks. its a cellular looking antenna that fits in the whole that is already there. advanced auto is where i got it. soon ill have newer pictures of my car so then you can see what it looks like.
Old Jun 5, 2005 | 07:26 PM
packetscan's Avatar
I like to see this.. My antena is always being a pain in the butt.
Old Jun 7, 2005 | 03:17 PM
sparkyssb's Avatar
ok.will do
MikesChevelle
Nov 23, 2024 11:17 AM
rbuswell
Nov 17, 2016 04:54 AM
fulloboost
Sep 12, 2015 08:03 AM
Samedi
Aug 12, 2015 01:54 AM
classymax420
Aug 6, 2015 06:35 PM
