Need help getting better low end
OK. Mevi is getting installed next week. This will handle my high end power. I know the max has good mid range power.
I need advice on what I can do to get better low end power.
Here are my mods:
Frankencar Intake
Warpspeed Y-pipe
Warpspeed High flow cat
Custom Flowmaster exhaust
H&R Springs
KYB GR2 Shocks
Exedy Clutch Stage I
18" Excel Rims (Im not changing these...i know they slow me down at low speeds)
MEVI (I will be installing it soon)
I know about headers....but 699 for 7-12 hp....or even the ecu programming for 599 for like 10hp and better air to fuel ratios thoughout the band....dont seem like enough gains to warrent that kind of cash.
Any ideas?
Here are my mods:
Frankencar Intake
Warpspeed Y-pipe
H&R Springs
KYB GR2 Shocks
Any ideas?
If you want to gain some low end back with the MEVI, you best bet is to get the ECU.
It will help in the low end as well as throught the power band, and if your spending the cash on the MEVI, you might as well take full advantage of it by getting the raised rev limiter.
yeah you sould def. get an ECU, yeah you gain 10hp at top, but think of the extra 600rpms you can travel through now. Also, you gain quite a bit of low end too, gets it almost back to stock.
If you really want low end power, get an 00vi + ecu. then you are rocking.
ECU will give you added midrange response/hp, not only "up top". And if you did not get the rev limit increase, you're not gaining anyting on average as opposed to the MEVI, vs USIM ... The extended rev limiter gives a better average HP.
So in short simple terms, the MEVI+No limiter gives the same AVERAGE hp # from 2-6.5k, whereas when coupled with the extended rev limiter gives a better overall (average) gain.
No MEVI should be done w/o an increased rev limiter. IMO.
Originally Posted by rsly33
Put your stock intake back on...
Open it up a bit to make sure you don't loose any top end. Remove the resonator from under the battery tray and drill a few holes in the side that faces the inner fender wall. This will give the stock intake another source of air to breath.
since you guys are talking about mevi's a little, i just put mine it but need to wire it up and have no directions. If anyone could tell me how to wire the harlan and map/baro switch, that would be great. also, which was is open and which was is closed on the mevi?
Originally Posted by happyricefob
get underdrive pulleys (UDP)...motostorm GD has it for $90 shipped i think. u can easily get around 5WHP across entire RPM range
yeah i would like to see the dyno... UDP is worthless..
should've gunned for an 00vi...
00vi doesnt sacrifice low end power....BUT...since u went with a mevi...go with the ECU...that way ur MEVI is effective for an even longer time since the redline is 7.2k...besides i thought it was more like 15hp in some areas for the ECU...
I put my stock resonator back on, removing the frankencar midpipe and saw a definate increase in low end tq. I still am running the K&N filter for the topend, its a great combination without all the useless noise..
Originally Posted by NmexMAX
Others have seen no gain at the track
ECU will help out low end, 00 VI would have been better over MEVI too for lowend, but too late. UDP will "help" put stock resonator back on intake, or stock intake all together ( I refuse to because I love the sound) Nitrous helps me out with the low end
5 hp could also be a variance in conditions of the 2 different dyno days.
Mar 12, 2020 12:06 AM
