Does anyone have the post on how to get the center air vents out of the dash?
Old May 17, 2001 | 06:12 AM
deezo's Avatar
I think when my amp was installed, the vents weren't lined up properly so I can't control them like I should.
Thanks in advance.
Old May 17, 2001 | 06:24 AM
AndyXXL's Avatar
Thanks in advance.
That's what happened to me when I got my cd player installed. Just pry them out with a screwdriver, that's how i did it
Old May 17, 2001 | 06:28 AM
Daddy Fat Sacks's Avatar
I believe you have to take the entire dash apart. Start from around the shifter, then up to where the radio and a/c is, then the upper piece can pop out after the others are out. If you don't know where the screws are, go to
https://maxima.org/shoptalk/sub_modi...t1/index.shtml
i hope that helps
Old May 17, 2001 | 06:45 AM
Daniel B. Martin's Avatar
Install Doctor
Thanks in advance.
Install Doctor has good instructions with photos. This item ...
http://www.installdr.com/InstallDocs...PDF/647021.pdf
covers removal and installation of the radio. You need do only steps 1 - 2. Since this is a PDF file you will need Acrobat to read it.
Old May 17, 2001 | 07:12 AM
deezo's Avatar
Thanks people.
Andy, we are going to have to talk soon but I have to work OT on Sat.
Daddy, keep me updated on the starter issue.
Daniel, thanks for the link.
Old May 17, 2001 | 08:10 AM
fast97maxse's Avatar
Re: Install Doctor
I have a 97 se.
did the clock bright/dim mod.
no problem prying up/off the dash part with the vents and clock.
But I can't get it to snap back into place at the bottom of that piece.
Any hints/tips?
thanks
Old May 17, 2001 | 08:12 AM
AndyXXL's Avatar
Alright, let me know when you wanna meet up.
Old May 17, 2001 | 08:15 AM
AndyXXL's Avatar
Re: Re: Install Doctor
Originally posted by fast97maxse
I have a 97 se.
Any hints/tips?
thanks
I just pushed it real hard with my both hands and it snapped back into place but be carefull you might break the plastic clip on the bottom.
Old May 17, 2001 | 08:21 AM
deezo's Avatar
Will do.
Old May 17, 2001 | 02:20 PM
WaarrEagle's Avatar
I have a 97 se.
Any hints/tips?
thanks
I think you are talking about the piece with the clock snapping down at the bottom? If you are just pull down from the clock indent and it should go in. That worked for me.
Old May 17, 2001 | 05:27 PM
deezo's Avatar
I just fixed those vents. When you want to put that console back in, you can push it in vertically and it snaps it with no problem. Don't put the top in first. If you do, this is when you get the problem.
Old May 18, 2001 | 06:25 AM
thanks
I'll try that
I thought you had to put it back
in reverse order...
Old May 18, 2001 | 06:31 AM
deezo's Avatar
thanks
I'll try that
in reverse order...
I did the reverse order and the bottom wouldn't line up to go in. When I push it in vertically all at once, it went in with no problem. Snap!!!, and that was it.
stevesmax
Dec 17, 2020 11:57 AM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
dauntlessmax
Aug 5, 2015 10:29 AM
