1996 max o2 senor 1 bank 1?
Jun 7, 2005 | 07:46 AM
which o2 sensor is sensor 1 bank 1? is it the right(passenger) or left (driver)
Jun 7, 2005 | 07:50 AM
What trouble code did you pull?
Jun 7, 2005 | 07:56 AM
the code was p0135
Jun 7, 2005 | 07:59 AM
P0135 = DTC 0901
0901
Diagnostic Trouble Code 0901 points to a problem with the Front Heated Oxygen Sensor, Right Bank. The right cylinder bank is also called the rear bank. It is cylinders 1,3,5.
FYI: http://www.courtesyparts.com/A32_O2-sensors.html
BTW -all the info I provided you is in the stickies.
It's the one on the Y-pipe closest to the firewall.
Jun 7, 2005 | 08:00 AM
i know the the info is on the stickies, but i had been seeing some things that were a little unclear, so i just wanted to clarify. thank you very much!
Jun 7, 2005 | 08:01 AM
You are welcome.
