Question about BCM
Old Jun 11, 2005 | 09:35 PM
HarrisH's Avatar
Question about BCM
I have a 97 GXE with sunroof and power seats, no auto a/c... I think I messed up my BCM while replacing a LED in the ignition switch, how can I reset the BCM I took out 2 of the 3 wire harnesses and still no diff., do I have to start the car while the harness is out? If I have to get a new BCM does it matter what year or trime the car is, or does it have to be a 97 GXE with sunroof etc...
Old Jun 11, 2005 | 09:59 PM
alpimax99's Avatar
try diconnecting the battery and hold down your brake to get all the power out of the system. then reconnect the battery and try to start the car again. if that doesn't work i can send you the other info out of my max fsm
Old Jun 11, 2005 | 10:11 PM
Black Maxima
I have the same problem as you. I brought it to the dealer and they 'd me. They couldn't find the exact problem, like wires or anything, but did trace it down to the BCM. It is a ~$900 part.
alpimax99 - Help me out too! You think that brake thing will work?
Old Jun 11, 2005 | 10:12 PM
alpimax99's Avatar
the brake thing would take out all the power out of the car. i think that the is a sticky for the bcm
Old Jun 11, 2005 | 10:13 PM
alpimax99's Avatar
it might work
Old Jun 11, 2005 | 10:16 PM
Black Maxima
Would it be possible to send me some text on this? I thought I read all there is on this BCM, but still soaking up some knowledge...
Old Jun 11, 2005 | 10:34 PM
alpimax99's Avatar
Erase the memory by CONSULT (refer to EL-170) or turn the ignition to “OFF” position and remove 7.5A fuse (No. 56 ,
located in the fuse and fusible link box).
Old Jun 12, 2005 | 07:20 AM
HarrisH's Avatar
Did you try junkyards?
Old Jun 12, 2005 | 07:48 AM
Black Maxima
No, not yet. I'm pretty busy lately, I will soon I hope.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
