Manual transmission spewing oil through overflow !!! ???
Old Jun 13, 2005 | 11:54 AM
charancon's Avatar
Hey guys, I changed my transmission fluid about 25000 miles ago and about 10000 miles later I verified the level and it was just fine.
Now, last week I was on a long highway trip (been doing just that in the past year as well) and when I stopped, I noticed my car smelled like oil.. I checked and behold, a good amount of transmission oil came through the overflow tube that oversees the transmission ?? Whats up with that ?? Anyone had any idea ? I didnt notice anything wrong with the shifting...
Thanks,
Cha
Old Jun 13, 2005 | 12:47 PM
joecraps's Avatar
Wow, that doesn't make sense. The MT fluid should not be under pressure so as to come out that overflow tube unless it were overfilled - but that is remote seeing as you have checked the level and driven it many miles.
Wait...have you driven through deep water lately?? That overflow tube would make a perfect point of entry and oil would be the first thing to come out on top of the tranny. I would drain that sucker and see what comes out (gush of water) right away!
Old Jun 13, 2005 | 01:49 PM
matty's Avatar
You probably put too much oil in the case and when Oil is Heated up it will expand quite a bit and will find a way out, this being your overflow tube...its there for a reason....if that was KINKED, you would have blown out your axle seals
-matt
Old Jun 13, 2005 | 01:52 PM
charancon's Avatar
Ok, guess I'll have the oil level checked asap and also have an oil change made if necessary. Will keep you guys updated...
C.
Old Jun 13, 2005 | 01:55 PM
matty's Avatar
C.
I wouldnt think it was water, thats the last thing i would think.
you prob put in too much Oil, and when it expanded on your long trip, it happend
-matt
Old Jun 14, 2005 | 07:04 AM
joecraps's Avatar
-matt
Well, water intrusion was all I could come up with since he stated that he checked the level and has put alot of miles on it since.
Also, its pretty damn dificult to overfill our MTs - the fill hole is vertical and drains the excess - unless one is an idiot and bolts it back in place right away.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
pjgreek
Sep 9, 2015 09:30 PM
