P1130 Error Code
Old Jun 17, 2005 | 09:45 AM
bklynzsleepy's Avatar
P1130 Error Code
I got a P1130 error code from the obd-ii reader. What does this code mean and how can this be fixed? I've searched around cant find anything on this error code...
Old Jun 17, 2005 | 10:16 AM
njmodi's Avatar
Do I get a tax break?
Double check the code - if the CEL is still set, pull the code using the ECU screw method outlined in the stickies... then get back to us. The FSM doesn't have the code you pulled listed (at least I couldn't find it).
Old Jun 18, 2005 | 05:40 AM
ckari's Avatar
I had P0130 - bad o2 sensor. Are you sure its P1130 ?
Old Sep 22, 2008 | 03:11 PM
Konstantin's Avatar
I have the same code. Actron Website says its related to "Swirl Control Valve Solenoid" anyone knows WTF this is?
Old Sep 22, 2008 | 05:26 PM
B_Eaze's Avatar
go to the first thread in the stickies, the answer is there
Old Sep 22, 2008 | 05:40 PM
pmohr's Avatar
No more Maximas...
Old Dec 5, 2010 | 07:29 AM
FalconFixer99's Avatar
My Check Engine Light illuminated and I download codes P1130 & P0325.
P1130 is Swirl Control Valve Control Solenoid Valve
P0325 is Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
Inspection of engine bay revealed unidentifiable vacuum line disconnected because the mounting bracket rivets failed and bracket vibrated the hose off.
I reset the codes, reconnected the vacuum line and used automotive superglue to mount bracket back to manifold.
Since reading posts looks like the vacuum line is for the swirl control (cold start) valve. I googled and found:
The purpose of the cold start valve is to inject fuel into the intake air stream when the engine is cold (and the starter operating) in order to richen the fuel/air mixture for easier starting.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
