2005 G35x rims on a 4th gen
Old Jun 19, 2005 | 11:42 AM
Dejenn21's Avatar
my friend just bought a new G35x and wants to get new rims...i am thinking about getting his stock rims from him and maybe use his tires also...will those rims and the tires fit into the wheel well of my 4th gen max?
Old Jun 19, 2005 | 11:49 AM
sunten1
If i am correct i think theyll fit just fine...but i am not sure how it will look....
Old Jun 19, 2005 | 12:07 PM
NAPhi_Shift's Avatar
i think it should fit. i have stock 350z 17" rims on my max. ill be posting pics soon, since im just new around here.
Old Jun 19, 2005 | 12:16 PM
maxspeed96CT's Avatar
The original VQ...
They should fit fine, if you dont want them, Send me a PM and i would love to buy them off your friend.
Old Jun 19, 2005 | 01:49 PM
TrackSmart's Avatar
I've seen max's on here with those rims. So the rims should fit (I don't know if they needed spacers or not).
However, I think the tires may have a larger diameter than your maxima's tires which would throw-off the accuracy of your speedometer a bit.
I'm not entirely certain, but it would be worth checking on.
Old Jun 19, 2005 | 01:56 PM
MDeezy's Avatar
should fit check with the tire calculator in the tire section to know more about the speedo.
Old Jun 19, 2005 | 02:36 PM
ChriSX's Avatar
I think it will be very nice with the G35x rims ! I plan to put this rims on my max next summer !
Old Jun 19, 2005 | 04:39 PM
maximazation's Avatar
arent the g35x rims the same as the regular g35 sedan and coupe?
Old Jun 19, 2005 | 08:27 PM
yeah i think their all the same design with the exception of the size. stock are 17" i believe, unless his friend paid for 18"s, which i think are too heavy. 17"s look good enough and offer the best perf. IMO
Old Jun 20, 2005 | 12:32 AM
the 17s and 18s look very similar, but the g35 coupe with the 18s look much better IMO. the 17s look somewhat odd.
Old Jun 20, 2005 | 07:33 AM
2 Da Max's Avatar
uhm isnt that car rwd? i thought the rims would offset would be different because of that? or not?
Old Jun 20, 2005 | 09:55 AM
DR-Max's Avatar
Good point 2 Da Max. I have heard that you wouldn't be able to use the center cap on because of that. Something about the splined end of the drive shaft sticking out. Maybe I'm wrong. Do a search in the forum.
Old Jun 20, 2005 | 10:27 AM
texasluva's Avatar
Ive got the 350z rims on my car. The G35 rims will fit on your car but the tire size is different because it is RWD.my rims are the same way, 2 of my tires are 7.5 and the other 2 are 8's rotating them isnt to cool because they are different sizes. I can only rotate them front to back. They still for in my wheel wells but when the 8's are up front there is a visual difference. Also the tires are going to be directionals. I love the 350z rims on my car but when my potenzas wear out im getting rims that are all the same size all the way around. It is just food for thought. They will look sick on there but there will be a size difference.
Old Jun 20, 2005 | 12:45 PM
Dejenn21's Avatar
the only dif between the g35x and the g35 sedan is that the X has all wheel drive
Old Jun 20, 2005 | 02:38 PM
tbergma1's Avatar
the bolt pattern is a 114.3mm or 4.5". Dont know about the offset. I have 17" rims from a 2003 max and looks good.
MAXSE5SPD
Sep 17, 2022 04:00 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Violator
Sep 9, 2015 10:14 AM
adamgalazka
Sep 8, 2015 01:27 PM
Lowered_a33
Sep 1, 2015 07:49 PM
