Sway Bar Bushings?
Old Jun 20, 2005 | 02:44 PM
AxisKill's Avatar
Sway Bar Bushings?
my car would constantly make squeeking sounds over any type of road (straight, bumpy.. you name it). I would have to turn the music up louder to shut out reality...
It got to a point where i couldn't stand it anymore, and coincidentally soon after that point it was determined that my car needed some changes.
2 brake pads, 2 calipers, 2 rotors, and 2 brake lines later my car still squeeked... so i went to someone to have it checked out.
It turns out that my sway bar is making the noise.. but not the sway bar particularly, but *here's where you come in i need that part name* the bushings to it?
It's a spring like part im guessing it's at an angle, and i was told it's about $40 a peice (and i need 2 of them).
i was wondering if anyone knows what the exact part is called / if anyone has diagrams? thanks
Old Jun 20, 2005 | 04:00 PM
dukelubas's Avatar
Org Lurker
I just changed my sway bar endlinks this weekend. I had the same squeaking you described and so far it hasnt shown up again. Go to any competent auto parts store and ask for two endlink kits for the front sway bar (mine were made by Moog, urethane and came with a grease fitting). Shouldn't cost you more than $10-$20 each.
Old Jun 20, 2005 | 04:47 PM
AxisKill's Avatar
nice, now did you replace just the bushings or the whole kit?
http://oem.thepartsbin.com/parts/the...r+Link+Bushing
or
http://oem.thepartsbin.com/parts/the...y+Bar+Link+Kit
Old Jun 20, 2005 | 05:01 PM
Pimpmobile's Avatar
I have the same problem, I have some nice new bushings coming from ebay
Old Jun 20, 2005 | 05:03 PM
Jatan's Avatar
Great diagram here: http://www.courtesyparts.com/energys...on/maxima.html
Cheap place to buy:
http://www.suspension.com/nissancars.htm (about half way down)
FRONT SWAY BAR FRAME BUSHING SET
7-5118 (20mm)
$7.00
FRONT SWAY BAR ENDLINK GROMMETS
4803-G (endlink grommets only, 4 required)
$1.00 each x 4 = $4.00
1(800)-291-5340 ORDERS ONLY
Old Jun 20, 2005 | 08:21 PM
AxisKill's Avatar
thank you very much
Old Jun 20, 2005 | 08:57 PM
dukelubas's Avatar
Org Lurker
I bought the kits in the second link. Nobody carried the actual frame bushings locally so I'll just replace them later on when I get a chance.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
