fuse problem
Old Jun 27, 2005 | 03:20 PM
trubd's Avatar
fuse problem
My car illumiation does not turn on anymore. Before when i turn my lights on the instr cluster would light up, the ac buttons and clock would light up and bose hu. Also my radio does not turn on anymore. What could be the problem?
Old Jun 27, 2005 | 03:24 PM
maximavqpower97's Avatar
Probably got the wrong fuse? also your battery clean it out with a sand paper.
Old Jun 27, 2005 | 04:58 PM
MIXXMAX's Avatar
For the illumination, maybe check the dimmer switch. Is it turned all the way off? For the radio, pull the fuse and see if it's good or not, and replace it with the same fuse rating if needed.
Old Jun 27, 2005 | 05:34 PM
dharrison's Avatar
I would say that it is the dimmer wheel. Sometimes when I am detailing I don't even notice and accidently slide it. Some of the time I'm like "#($*)#$(*" and it is about the last thing that I check.
Old Jun 27, 2005 | 06:00 PM
PandaXpress's Avatar
ok man..solution is here = when you turn on your lights (when the car is off)..do you hear a beeping sound?...maximas are naturally supposed to alarm you if your lights on while your car is off...to remind you to turn them off...it there is no beeping sound when your car is off and the lights are on...your tail lights are out man...you blew a fuse...start by changing the tail lights fuse...(it can sometimes effect illumination)...then when you change all 2 fuses inside your fuse box..open your hood and change the 1 in there...after that go to change the 3 fuses for electronic parts inside the car...I blew out my tail light fuse and my illumination turned off inside the car..so changed them the tail fuses and electronic part fuses and it started working again...so lemme know>>>>>
Im fully aware it sounds stupid that your tail lights might be the problem for illumination inside the car..but try it and let me know.
Old Jun 28, 2005 | 05:57 AM
trubd's Avatar
ill try it thanks. Ill let you guys know. BTW the dimmer swtich I tired no go. Plus my radio doesnt turn on either. So it has to be a fuse sumwhere.
Old Jun 28, 2005 | 08:14 PM
konak85's Avatar
I hate to butt in, but where is the cruise control fuse, looked all over interior panel and under hood panel.
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
