Defogger switch lit? -->
Old Oct 10, 2000 | 02:09 PM
Eric L.'s Avatar
I noticed the other day that my rear defogger switch is not lit at night. The orange light comes on when I press the switch, but the little picture on the button isn't lit. Since the hazard light switch is lit at night, I wonder if the defogger switch should be lit too.
So, is your defogger switch lit at night?
Old Oct 10, 2000 | 03:27 PM
brandonj's Avatar
Mine is, but my hazard switch isn't. Go figure.
Old Oct 10, 2000 | 03:49 PM
Bernie Lomax's Avatar
I just went and looked
Mine both light up.
Old Oct 10, 2000 | 04:23 PM
Eric L.'s Avatar
Re: I just went and looked
Originally posted by Bernie Lomax
Mine both light up.
Aw man, my car is falling apart!
Thanks.
Old Oct 10, 2000 | 09:52 PM
amixam69's Avatar
Re: Re: I just went and looked
I managed to fix mine... i took it appart and replaced the little bulb.. IT WAS A PAIN IN THE @$$, guys.....
but worth the trouble...
they sell the bulb at radioshack actually... it's a tiny glass bulb with little wires coming out..like $1.00
the only way i can tell you to do it is figure it out...
can get greasy and DON"T loose the little spring...
or any part for that matter
and VERY easy to break... but i managed without trouble..
expect to spend a long time figuring it out and putting it back together.... wish i had little fingers
Old Dec 2, 2000 | 11:44 AM
mo'max's Avatar
Defroster and Hazard Bulbs
Hey amixam69,
You don't happen to remember the radio shack part number for the bulbs you bought? I need to replace all of mine.
btw there is a way to replace the bulbs w/o having to take the switch as far apart as you did (down to the greasy spring). But admittedly I didn't figure it out until I took it apart down to the greasy spring. Damn what a B!tch!!
Old Dec 2, 2000 | 09:41 PM
mo'max's Avatar
Re: Defroster and Hazard Bulbs
Originally posted by mo'max
Hey amixam69,
I found your previous post where you give the p/n. they are a great find! Thanks for your post. Got all my lights working now.
Old Dec 4, 2000 | 08:07 AM
Wayne
What was the Radio shack p/n for the bulbs? Can find it
Old Dec 4, 2000 | 09:06 AM
CFC's Avatar
CFC
Radio Shack Part number....
p/n 72119
Box number 272-1092c
about $1.50 for a box of 2
they are called 12V mini lamps
Hope that helps.
Old Dec 4, 2000 | 09:41 AM
Wayne
Thanks!!!
Old Dec 4, 2000 | 10:26 AM
JacksMax's Avatar
Its 272-1092C
Wayne, doing a search on "bulb" this was found:
https://maxima.org/forums/showthread...4&pagenumber=3
Adidas_boy - I fixed the lights on my hazard switch and my rear defroster. Thanks to an earlier post by amixam69 I was able to get replacement lamps. He found them at radio shack p/n 272-1092C (I paid 1.49 ea. for a pack of 2 lamps). Let me know if you are still trying to fix yours.
Jack
Old Dec 4, 2000 | 12:54 PM
Wayne
Thanks JacksMax! I going to try knocking on the dash first before I take the dash down. Dammm, I'm not looking forward to doing it!! I had hell taking it down the first time to replace my radio
Old Dec 4, 2000 | 01:06 PM
krell
Seen this before
I noticed this the other day after I had taken the top part of the "waterfall" off to wire my Valentine into the electrical system. My defogger was no longer lit. So I popped the top part off again and made sure the wiring plug was tight, and poof, the button was lit again.
It really shouldn't be hard to take the top piece off!
Old Dec 4, 2000 | 03:28 PM
GarthG's Avatar
Ok, I had this problem on my car. . . Whenever I took the dash apart the bulb would go out. . . Here is my fix. . . Tap the dash to the upper left of the switch pretty firmly a couple times. . . The light comes right back on. . .The lights are seated in a way that is very poor and so they are easily disloged.
Old Jan 3, 2002 | 11:30 PM
maxima168's Avatar
PART NUMBER !
Anyone knows the o.e.m. Part number to the led in the fan speed ****. I lost to blue condom thingy when I was replacing it with a radio shack bulb it works fine, but it's mad ugly with out that blue condom because it gives out yellow light. If any body know. Please help a brother out. Thanks
Old Jan 4, 2002 | 12:48 AM
Weasel's Avatar
Thanks.
Mine just started another rattle yesterday... argh.
Curse of the Minima.
Old Jan 29, 2002 | 02:46 PM
Max96LSU's Avatar
Re: PART NUMBER !
Radio Shack 272-1092c (Package of 2) $1.49
Old Jan 29, 2002 | 03:55 PM
maxima168's Avatar
thanks a lot for the help guys. but i didnt need the l.e.d. i need the blue condom that went on the led. on my packaged i payed 1.49 for 3 when it said 2 on it hehehe. i guess i was lucky. with out the blue condom it looks mad ugly because its all yellow.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
