Knock Sensor Will It Kill Car?
Old Jun 30, 2005 | 12:57 AM
eLMo's Avatar
Ok so I checked the codes and got a Knock Sensor code. I read the faq and all they say is that it will just affect the performance of the car. I also read the article on http://www.motorvate.ca/mvp.php about it. All they say is that it will affect the performance of the car. Since I won't be racing anyone I don't care that much about performance. I want to know if I don't change it anytime soon will it affect the life of the car at all.
Also I did no searching for this yet but what is the Front Right Htd 02 sensor heater?
Old Jun 30, 2005 | 01:45 AM
Chadly's Avatar
I'm not 100% sure about the knock sensor as I have been trying to research this a lot lately too but as far as I have read it doesn't sound like it's a required part but as you know it will affect the performance of the car.
As for the front right O2 sensor.... I just replaced my own... if you got the code for it, it's really easy to replace but it's kind of an expensive part, about $75. There are tons of posts about what exactly the O2 sensor does so I won't try to explain it but I know that in conjunction with a "possible" bad knock sensor, it reduces gas mileage and performance but I don't think your car will "break" if you don't fix it right away.
I got the front right O2 sensor code AND the knock sensor code but only replaced the O2 sensor for now. Since the knock sensor is so expensive and I'm a broke *** college student I only replaced the O2 sensor. Once I replaced the O2 sensor and reset the ECU, I no longer got the code for the knock sensor but I'm waiting to see if it comes back anytime soon.
Old Jun 30, 2005 | 01:49 AM
dayglo's Avatar
its there to dectect knocking in your engine so if its broken...youre enging could knock im not sure if it will even though it sets itself to a 'safe mode'
use 94 octane till u get a new parrt
Old Jun 30, 2005 | 06:41 AM
nadir_s's Avatar
vicodin ... gift of life
the part is $79 bucks - brand new OEM.
Your gas mileage will suffer and you will lose $79 in a couple of months that way.
Old Jun 30, 2005 | 07:00 AM
kbmaxima's Avatar
+1. spend the 80 something dollars now, because you're going to waste a LOT on gas in the coming months. just watch those gas prices go up.
Old Jun 30, 2005 | 07:23 AM
NmexMAX's Avatar
dot dot dot ...
And the porformance will suck as.s. It wont kill your car, I had a dead KS for about 2 years, and now my car has 229k, and runs like a dream ... so stop being paranoid, it was not stated in the stickys as being bad to your car's health, so then why are you asking?
Old Jun 30, 2005 | 10:23 AM
eLMo's Avatar
It's funny that you say it because my cousin owns a shop so I called him what's a knock sensor and the O2 sensor he said you got the knock sensor code because of the O2 sensor code. O well. I will keep searching for the O2 sensor repair.
Why you on my case with every topic I make lolol? I wanted to make sure that they didn't forget anything. I also learned something from this no one mention in the stickeys that it kills gas mileage. So this is gonna make me change it.
Old Jun 30, 2005 | 10:32 AM
Bobo's Avatar
With the mileage you put on, what would possess you to drive for about 2 years with a dead KS particularly given you said performance sucked?
Were you just lazy or too cheap to replace it?
Old Jun 30, 2005 | 01:25 PM
NmexMAX's Avatar
dot dot dot ...
I was used to it ...
Old Jun 30, 2005 | 01:52 PM
SiCkBLaCKMaX99's Avatar
the knock sensor is only $79???
Old Jun 30, 2005 | 01:54 PM
MDeezy's Avatar
you gas consuption will be even worse with the o2 and KS being faulty.
Old Jun 30, 2005 | 02:59 PM
NmexMAX's Avatar
dot dot dot ...
Check sleaze , or the F/S forums, I sold one for $75 ..
Old Jul 1, 2005 | 01:47 AM
Chadly's Avatar
That's what I was thinking, but then again, I have been using like 87 octane gas so I wouldn't be surprised if there was actually some knocking.
I know Autozone wanted like $169! Definately too expensive. On EBAY they go for about $80-110 I think. You'll have to shop around.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
follyburr
Aug 7, 2015 09:50 PM
yat70458
Aug 3, 2015 01:16 PM
