A/C - Heat ....only work on setting 4. 1-3 Broken... HELP
Old Jun 30, 2005 | 06:26 AM
JetBlack SE's Avatar
I got a 95 Maxima SE with a Manual climate controller. The problem is that for some reason both the A/C and the heater work perfectly well, in all positions and settings except for the 1-4 power dial. Basically when I turn from OFF to 1 then 2 then 3, nothing happens as though I didnt touch it at all, however, when I reach 4 it turns on FULL BLAST.
I'm happy that it works in someway period, but I need some help to get the thing to work in the other 3 settings.
THANKS FOR THE HELP
Old Jun 30, 2005 | 06:29 AM
Loe max's Avatar
Change the switch
Old Jun 30, 2005 | 06:32 AM
packerZ's Avatar
fan fix
Had same problem! Replaced resistor (on passenger side of airbox) for less than $20... fan blows in all settings!!
Old Jun 30, 2005 | 07:03 AM
97BlackSEGold's Avatar
Yeah its the resistor, there is a write up for this problem in the stickies
Old Jun 30, 2005 | 10:37 AM
Thanks alot, ima gonna get on it asap, will be back with details
Old Jun 30, 2005 | 11:07 AM
eLMo's Avatar
http://forums.maxima.org/showpost.ph...2&postcount=31 I read through the stickies last night and found this
There is a resistor assembly mounted on the air duct close to the blower motor. That part has failed. It is used to control fan speeds 1, 2, and 3. Speed 4 is the maximum blower motor speed, so no resistors are involved. Replacing the resistor assembly is something the home mechanic can do. The only tool needed is a Phillips screwdriver. The replacement part costs about US$25.
The blower motor is located just above the passenger's feet. Look at the wires leading away from the blower motor. Just inches away from the blower motor there is an electrical connector located on the air duct. That's the resistor assembly. It is easy to remove and replace.
Replacement is the usual remedy. However, if a spot of localized damage is seen it may be repaired with a soldering gun.
There is a good photo of the blower motor and resistor assembly in the Haynes repair manual, page 3-8. If you don't already have a copy of this book, please get one. It will be money well spent.
a) Move the front pass seat all the way back (for convenience)
b) Remove a harness connector (with 4 wires I think) running into the bottom of the blower motor.
c) Remove the 2 philips screws that hold the blower motor resistor in place.
d) Put new one in, reverse install.
Blower Motor Resistor Part Number: 27150-1E405
You can get it here:
http://www.nissanparts.cc/cart/?pn=27150-1E405
Should be $28 at your local dealer. It's $28 delivered from discount Nissan parts sites.
Edit: If you are handy with a soldering iron, you can try to fix it yourself. See this thread.
Old Jun 30, 2005 | 02:47 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
bye bye resistor
Old Jul 1, 2005 | 11:44 AM
1995WhiteMaxima's Avatar
wow
if i had read this sooner I would never have bought the stupid switch and stopped screwing around with the blower fuses.
Thanks I finally know what to do.
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
